PBR not working properly
UnivoiceLLC
I am trying to get PBR working porperly and have had no luck please tell  me what I am doing wrong..
here is my current config for the PBR   NOTE:  I subjected 50.196.73.144/28 in to 2 networks 50.196.73.144/29  and 50.196.73.152/29   i am using "sdm prefer extended-match'  My goal  is to get the Vlan4 or 50.196.73.144/29 to route out the Vlan3  50.197.73.152/29 network via gateway 50.196.73.158 directly connected to  port  faste0/17 and computer is on faste0/18
now the following
interface FastEthernet0/17
switchport access vlan 3
switchport mode  access
interface FastEthernet0/18
  switchport access vlan 4
interface Vlan1
ip address 50.198.250.125  255.255.255.248
ip access-group 150
in  no ip redirects
interface  Vlan2
ip address 50.198.250.118 255.255.255.248
interface Vlan3
ip  address 50.196.73.157 255.255.255.248
interface Vlan4
ip address  50.196.73.150 255.255.255.248
  ip policy route-map comcast2
ip  default-gateway 50.198.250.126
ip classless
ip route 0.0.0.0 0.0.0.0  50.198.250.126
ip access-list extended acl-pbr
   permit ip any any
route-map comcast2 permit 10
match ip address acl-pbr
set ip next-hop  50.196.73.158
   Thank in advance
anisaini
Information regarding the platform missing, You can try the below steps to further isolate/fix the issue.
1. modify the acl matching route-map as it has match any any, so just match the specific tarffic of your interest
2. ensure that the traffic of interest hist the interface where PBR is applied
3. some platform will not show the ACL hits in route-map of PBR as this will be fast switched and no cpu processed
4. ensure that you have the correct SDM template enable, like routing or application(for ME switches)
5. check if the device to which you are sending these packets to has reverse route so that the routing path is not broken
6. to ensure that the packets are hitting PBR or if PBR is working, enable the debug ip policy and this will gibe you the clear picture and you can proceed accordingly.
Most likely issues are covered above and hence shd be resolving the issue, if still not working provide follwing
1. debug ip policy
2. wireshark cap on exit interface of this witch
reply if this helps
5 Replies 5
blau grana
Level 7
Level 7
Hello Fernando,
Please delete other duplicate post.
What do you mean that PBR is not working properly?
Is it working? Is it not working? How is it working?
Please issue these commands on router:
ip routing
no ip default-gateway 50.198.250.126
And try to change ACL-PBR like this:
   permit ip 50.196.73.144 0.0.0.7 any
   deny ip any any
Are you able to ping 50.196.73.158?
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Thank you for the quick replay I ahve done as you say and still having same issue I can post entire config if you like.
Abzal
Level 7
Level 7
Is computer on the subnet of VLAN 4? Gateway is properly configured on PC by pointing to VLAN 4 interface?
What is the model of the switch?
Best regards,
Abzal
anisaini
1. debug ip policy
reply if this helps
Was this issue resolved,..?
