PBR policy rejected
Junior Mateus
Hello Everbody
I have 2 router ( setting as HSRP Standby )
My lan point to the defaut gateway of the standby address ( 10.30.21.6)
On the Router 1 (high priority standby ) i have configured on the lan interface a PBR that redirect traffic http/https  from ip 10.30.104.0/24  from my lan to the next hop of 10.30.21.4 (R2)
I have to mention that R1 and R2 are on the same segement
here is the detail configuration
R1
****** LAN Interface Configuration *****
interface GigabitEthernet0/0
description LINK TO LAN
ip address 10.30.21.1 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow monitor MYMONITOR input
ip nat inside
ip virtual-reassembly in
standby 0 timers 2 4
standby 10 ip 10.30.21.6
standby 10 priority 200
standby 10 preempt
standby 10 name HSRPGRPE1
standby 10 track 10 decrement 150
ip policy route-map PBR_104
duplex auto
speed auto
service-policy input QOS-MARKING1
end
*****   SH ACESSS-LIST
Extended IP access list 104
    10 permit tcp 10.30.104.0 0.0.0.255 any eq www
    20 permit tcp 10.30.104.0 0.0.0.255 any eq 443
***********SH ROUTE-MAP
route-map PBR_104, permit, sequence 10
  Match clauses:
    ip address (access-lists): 104
  Set clauses:
    ip next-hop recursive 10.30.21.4
  Policy routing matches: 0 packets, 0 bytes
route-map PBR_104, permit, sequence 20
  Match clauses:
  Set clauses:
R2
interface FastEthernet0/0
ip address 10.30.21.4 255.255.255.248
ip nat inside
standby 10 priority 150
standby 10 preempt
standby 10 track 20 decrement 100
duplex auto
speed auto
end
On R1 here is the debug of debug ip policy
IP: s=10.30.104.56 (GigabitEthernet0/0), d=195.8.12.141, len 40, FIB policy rejected(no match) - normal forwarding
sh access-list
    10 permit tcp 10.30.104.0 0.0.0.255 any eq www (331 matches)
    20 permit tcp 10.30.104.0 0.0.0.255 any eq 443 (7 matches)
  Match clauses:
  Set clauses:
  Match clauses:
  Set clauses:
As YOU CAN see Nothing working  on the route-map and the PBR
I don´t know what happen ?
The core switch is a better place for PBR since you can do better manipulation there. You can set up an SLA to verify the 2nd router is up and send the traffic there if it is. If its down, it can route as normal.
6 Replies 6
Richard Burts
My first question would be where is 10.30.104? That does not match the subnet of the interface that you show us. So what interface does it connect to?
Rick
Rick
hello, thank you for your question,
The 10.30.104.X is on vlan of my CORE SWITCH
and my CORESW have a default route  to the HSRP Standby address ( 10.30.21.6)
i have one vlan 21 on my CORW that have this address 10.30.21.2/29 and this interface are directly connected to the interface inside of the R1 ( 10.30.21.1/29)
interface Vlan21
description RESERVED-HSRP
ip address 10.30.21.2 255.255.255.248
interface GigabitEthernet2/17
description connected to Router 1
switchport
switchport access vlan 21
switchport mode access
spanning-tree portfast edge
ip route 0.0.0.0 0.0.0.0 10.30.21.6 250 name  virtual_HSRP
The Router 1 and 2 Process NAT the for internet
Thanks for the information. One thing I had wondered about was whether the PBR was configured on the right interface. It must be configured on the interface where the traffic arrives. And since the source address specified in the ACL did not match the subnet where PBR is configured I wondered if there was a mismatch. But your explanation clarifies that it is on the right interface. So I begin to wonder if the suggestion from Robert is something that we should check. Can you change the route map and specify a next hop that is not the other router - preferably a next hop is some other subnet. I know that it would not produce the result that you want but it would at least give you a chance to run the debug and see if PBR was not working because of the choice of next hop.
Rick
Rick
Hello , thanks, i have mouve the PBR to the Coresw now it working, thank all for your help !
rfalconer.sffcu
Level 3
Level 3
It looks like you're trying to redirect the matched traffic back out the same interface it entered on so it can travel to the other router. Is that correct?
I'm not sure if that type of redirection is supported with PBR.
