pbr route-map problems
petro-2005
Hi everyone.
I have a route-map with pbr rules on my asr router. There is a need to process with "and" logic two different acls with one route-map rule. But when i try to configure two
match ip address
rules router processes it with "or" logic. Also "continue" key didn`t work right in my route-map chain when i tried to commit "go to" logic to skip some rules. Are there any solutions?
19 Replies 19
Thanks for posting the configuration. I am glad that my suggestion was helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
Good stuff ! Can you post the working solution using these object groups ?
I posted test config under Richard Burts first reply
Hello @Richard Burts
Excellent suggestion, I still think of object-group ACLs as being ASA specific but they are indeed viable to routers also and would negate the high administrative burden that comes with a large access-list with lots of ace's  +5 mate
Kind Regards
Paul
I agree that the suggestion is a bit surprising. I also tend to associate object groups with ASA configuration. But Cisco does now support the concept on other platforms. And it seems the ideal solution in this situation.
Rick
