PBR seems to be not implemented
robad
Hi Guys, It's probably going to be long, but it's something that is very important for my team.
We are working in company in few Lab's environment that is connected to IT.
Our Gateway for all labs is currently 2 old 6500 working with VSS.
Each lab is connected to the 6500, and each lab have is own gateway to IT, I mean that for each lab, there are 2 links from our Gateway to IT Gateways. Now we are working with
route-maps
We should start use 2 9600 instead of the 6500. right now we got only 1 9600, so we have time to test it. we have 2 unused labs that we can 'play' with and check the configs.
I'll tell you what we are trying to do, and please, let me know if it should work like that, and also, if you think you have some better way - we'll glad to hear.
The 9600 is : 9606R
Version : (CAT9K_IOSXE), Version 17.3.4
ACLs & Route-maps :
Extended IP access list A-to-B
10 permit ip 43.43.43.0 0.0.0.255 40.40.40.0 0.0.0.255
Extended IP access list A-to-any
10 permit ip 43.43.43.0 0.0.0.255 any
Extended IP access list B-to-A
10 permit ip 40.40.40.0 0.0.0.255 43.43.43.0 0.0.0.255
Extended IP access list B-to-any
10 permit ip 40.40.40.0 0.0.0.255 any
route-map A sequence 5
match ip add A-to-B
set ip next-hop 40.40.40.1
route-map A sequence 10
match ip add A-to-any
set ip next-hop [IT uplink address]
route-map B sequence 5
match ip add B-to-A
set ip next-hop 43.43.43.1
route-map B sequence 10
match ip add B-to-any
 The strange thing that is for example the Group B to any is working, because I can ping 8.8.8.8 for example, and then move the
ip policy route-map
command from the int vlan, it's not working. so the
route-map
is working [at least for 'outside']
Pings between Group A to Group B not working....
It might be something with directly connected route or something, but I'm not sure...
Please advise . Thanks in advance
23 Replies 23
if he plug PC and config static IP that IP if it in same subnet of VLAN config with port he plug in then no issue at all, IF the ip is different then there is sure connectivity issue.
and the think is worse if you disable
proxy-arp
under the SVI of VLAN.
robad
Paul & MHM,
Let me see if I understand
1. If a user from some group will use another IP, that it's not part of my subnets , like 192.x.x.x , he won't be able to communicate - right ?
2. If the answer is Yes - so please tell me if the next idea is good  :
For interlab communication, I'll use static routes, like configuring on the 9600 this :
43.43.43.0 255.255.255.255.0 43.43.43.1
44.44.44.0 255.255.255.255.0 43.43.43.1
45.45.45.0 255.255.255.255.0 43.43.43.1
All group's A subnets will be routed via 'vlan 10' because it's allowed on the trunk with the 9600, and then the packet will go to the Group's Gateway, and from there to the specific SVI [for vlan 10/20/30].
And then use
route-map
only for packets that are going to IT [I must that each lab will get out from specific IT link]
thanks again guys
Hello
Would it not make sense to relocate the
intervlan-rotuing
onto the 9300 for Vlan 40-43 or use dynamic routing such as ospf between each IT group, this would then provide better administrative control over your network and negate having to add complexing routing policy’s and static routes.
Kind Regards
Paul
Paul,
So sorry, but what you are suggesting ? not sure fully understand.
[maybe config/draw will help me. or wider explanation]
Thanks in advance !
can you more elaborate you new design?
robad
Hi, here is the draw of my wanted network design [and this is how it works today with our old 6500 ]
NOTICE that I've changed the IPs and vlans name in order it'll be more separated and more clear .
My goal is that when a packet from any vlan from Group-A, wants to go to Group-B, it'll pass throw 9600 only and not go throw IT.
Now we are achieving it by
route-map
that sends any traffic from subnets in group-A to Group's B vlan 20 gateway [20.20.20.1], because this vlan is in trunk from the 9600 to Group's-B gateway. [and that's why we need route between labs. I think  that @paul driver  ask that, and said we don't need any route, because the 9600 have interface vlans for all lab's vlan. but we don't, we have on the 9600 one  "main" interface vlan for each group]
I think that who did it, , is to prevent some clients to connect PC/host to Group-A Gateway, and give it some other IP that is not part of our subnets, and he'll be able to harm the whole broadcast domain for his vlan or something like that that I'm not so clear with that....
So we have access-lists "groupA-to-GroupB" and "GroupB-to-GroupA" and then we are giving only the allowed subnets to go out to other labs...
In our new 9600 it didn't worked for some reason, so I tried to understand why is that, and also thought if it can be replaced by something else. like static route for each subnet, something like that [on the 9600, for group-B for example] :
ip route 20.20.20.0 255.255.255.0 20.20.20.1
ip route 21.21.21.0 255.255.255.0 20.20.20.1
ip route 22.22.22.0 255.255.255.0 20.20.20.1
sorry for the mismatch and complexity. not fully sure what I can/need to do to make things work better.
Thanks again guys for your time
you dont mention me so I dont see your reply until now.
you config is excellent except some point
in Core SW you need only one VLAN for example VLAN 100
you all VLAN in trunk between access SW and Core
you need to add VLAN 100 to access SW also.
Now do routing policy or doing static route toward the SVI of VLAN 100 in core
and that it.
one more point
please select different VLAN number in both Access SW I see VLAN 20 in both Acces SW that wrong.
robad
Thanks @MHM Cisco World  and @paul driver  for your great assistant !
At the end, we've chose to use a different vlan for routing between labs, and keep
route-maps
only for outgoing packets to IT
Thanks a lot !
