PBR / set ip next-hop
kgtnewmedia
could someone please advice how to change a next-hop for incoming SMTP traffic? I've successfully created PBR to redirect customer SMTP traffic to a different next-hop:
C6509#access-list 150 permit tcp 85.175.191.0 0.0.0.255 any eq smtp (customer LAN is 85.175.191.0/24; from customer to the internet)
C6509#access-list 160 permit tcp any 85.175.191.0 0.0.0.255 eq smtp (from the internet to customer LAN; doesn't work!)
C6509#route-map MAIL-Redirect permit 10
C6509#match ip address 150
C6509#set ip next-hop 20.10.10.10
C6509#route-map MAIL-Redirect permit 20
C6509#match ip address 160
C6509#interface Vlan100
C6509#ip address 85.175.191.1 255.255.255.0
C6509#ip policy route-map MAIL-Redirect
Redirect customer SMTP traffic from inside to the internet works as expected:
IP: s=85.175.191.111 (Vlan16), d=173.19.66.27, len 60, FIB policy match
IP: s=85.175.191.111 (Vlan16), d=173.19.66.27, len 60, PBR Counted
IP: s=85.175.191.111 (Vlan16), d=173.19.66.27, g=20.10.10.10, len 60, FIB policy routed
C6509#sh access-list 150
Extended IP access list 150
    10 permit tcp 85.175.191.0 0.0.0.255 any eq smtp (17 matches)
But the other direction (SMTP traffic coming in from the internet to 85.175.191.0/24) seems not working:
C6509#sh access-list 160
Extended IP access list 160
    10 permit tcp any 5.175.191.0 0.0.0.255 eq smtp
Any ideas?
Thomas
6 Replies 6
e.ciollaro
Level 4
Level 4
I think it's because PBR must be configured in interface receiving traffic; try configuring PBR on the  WAN interface (obviously you can split the route-map in the routemaps: one for incoming traffic (used on WAN inertf) and one for outgoing traffic (used on VLAN 100))
Let me know, bye,
enrico
PS: please rate if useful
thx, but the router has multiple WAN interfaces. (3x BGP full table)
Thomas
Why can't you configure PBR on all WAN interf ?
Another think I can't understand is why incoming and outgoing traffic has to be router to the same next-hop 20.10.10.10. Could you clarify ?
The next-hop (same for IN and OUT traffic) is an Anti-SPAM gateway. Filtering SMTP traffic from customer out of the internet should pass the gateway and SPAM should be filtered out. SMTP traffic from the internet to the customer should prefiltered too. Thats the idea behind :-)
Thx, did you fix the problem using Kazim suggestion ?
enrico
please change the acl:
no access-list 160 permit tcp any 85.175.191.0 0.0.0.255 eq smtp
access-list 160 permit tcp any eq smtp 85.175.191.0 0.0.0.255
kazim
