PC cannot ping server and vice versa
xm
This was a template provided by my lecturer and i cannot seem to figure out how to get the server and router to "talk" and successfully ping pc and vice versa. Please help
 I dont believe this is going to work this way. You should connect you Wireless Router to a switch and the server to a switch.
And the ping will work  from the PC to the server but not the other way around. I believe this is a limitation on the PacketTracer.
Take a look on the file I attached.
hi there thanks for the reply. I was still wondering if this is the only option or there is something else that can be done to the configuration of the server or router to get them to communicate?
You can connect the server on the Lan interface of the router and use IP address 192.168.x.x.
But, considering the simulator limitation, connect the server to the Internet interface seems not to work.
