04-29-2014 05:14 PM - edited 03-04-2019 10:52 PM
04-29-2014 06:14 PM
So do you have control of the other router?
If so I have never tried it but dual AS may work:
http://www.cisco.com/c/en/us/td/docs/ios/12_2s/feature/guide/fsbgpdas.html#wp1044665
04-30-2014 07:10 AM
Hello John,
if your objective is to test an eBGP peering with a 32 bit AS peer and the C7200-G2 has to play that role you need an IOS upgrade.
Releases 12.0(32)S11, 12.0(33)S, 12.0(32)SY | Cisco 7200 Series |
to build an EBGP session between the C7200 and another 32bit AS capable device there is a special 16 bit AS number for backward compatibility.
newly reserved AS TRANS# 23456 for interoperability between 4-byte ASN capable and non-capable BGP speakers
see
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/border-gateway-protocol-bgp/data_sheet_C78-521821.html
Hope to help
Giuseppe
