Per VRF TE | bgp next-hop on IOS-XR?
smailmilak
Level 4
Level 4
I want to configure this:
ip vrf TEST
rd 65500:1
route-target export 65500:1
route-target import 65500:1
bgp next-hop Loopback500
on IOS-XR 4.3.0
Does anyone know what is the equivalent command on IOS-XR?
Maybe?
route-policy TEST1
  set next-hop 1.1.1.1
vrf TEST
address-family ipv4 unicast
  import route-policy TEST1
Bit late now after 4 years
But for XR you can define an RPL as following:
route-policy test
if extcommunity rt match-any (65500:1) then
set next-hop x.x.x.x (loopback500 address)
else
pass
endif
end-pol
I am stuck in the same issue, maybe you find the answer???
Best regards
Martin
route-policy test
else
pass
endif
end-pol
