Showing results forĀ
Search instead forĀ
Did you mean:Ā
PFR Hub BR and Spoke BR Functions
snarayanaraju
Level 4
Level 4
Hello All - I learned as below
Hub Border Router: PFRv3 is enabled on the WAN interfaces of the BR, Path name and Path ID of the exit interfaces are defined on the Hub BR
Spoke Border Router: Learns Policy configuration from the Branch MC and the Exit interface are learned automatically
My question is WHY HUB BORDER ROUTER IS ALSO NOT LEARNING THE EXIT INTERFACE FROM THE HUB MC? WHY I HAVE TO DEFINE THE EXIT INTERFACE MANUALLY?
Thanks in advance for help me answering this
SAIRAM
16 Replies 16
Thank you Vasilii. I created a new thread as well to discuss more in detail.
https://supportforums.cisco.com/discussion/12980406/pfr-route-change
Do we have any document explaining this concept. I dont find it in IWAN design document or implementation documents. Thanks
If you are looking for configuration examples, please refer to iWAN CVD
http://www.cisco.com/c/en/us/solutions/enterprise/design-zone-branch-wan/index.html#~designs
