PfR in Multi-VRF envoriment
Ashwini Kumar
I have 4 VRF running in my network and want to understand, does PfR support multi-vrf environment? before implementing in my network.
Thanks & Regards,
Ashwini
Gaurav Mahajan
Hi Ashwini,
yes pfr v3 does support multi-vrf environment.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/pfrv3/configuration/15-mt/pfrv3-15-mt-book/pfrv3.html
Thanks Gaurav,
I would like to test this in Dev. ent. before applying it to Network.
Any suggestions that, I should be doing?
I got 7600 Series Routers. IOS 15.x.
Thanks & Regards,
Ashwini
Hi Ashwini,
Don't see this device 7600 device supported for IWAN.
Device
Cisco IOS Software Release
Hub/Remote Site
Cisco ISR 4000 Series Routers
Cisco IOS XE 3.14 or higher.
Hub or remote site.
Cisco ASR 1000 Series Routers
Hub site.
Cisco CSR 1000v Series Routers
Hub site (Master Controller only).
Cisco ISR-G2 Series Routers
Cisco IOS 15.5(1)T1 or higher
Cisco IOS 15.4(3)M1 or higher.
Remote site.
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Intelligent_WAN/release/notes/iwanrn.html
What exactly you want to test ?
