Need to configure Power supply redundancy
Tijo John
I have attached Show power and Show module command out put of Cisco7609 router. Could you please confirm can we do the power redundancy?
Now the router  is working in Power combined mode.
Vinit Jain
Hello
Yes, based on the logs, i dont think there should be any problem to enable power redundancy.
http://www.cisco.com/c/en/us/td/docs/routers/7600/ios/15S/configuration/guide/7600_15_0s_book/pwr_envr.html#40037
To enable redundancy, use the redundant keyword. In a redundant configuration, the total power drawn from both power supplies is not greater than the capability of one power supply. If one supply malfunctions, the other supply can take over the entire system load. When you install and power up two power supplies, each concurrently provides approximately half of the required power to the system
To enable redundancy, you can use the command power redundancy-mode redundant
Hope this helps.
Vinit
PS: Please mark the question as answered if your query has been answered.
--Vinit
Tijo John
Dear Vinit,
Thank you very much for your reply
