Pick a card...
steve.sarrick
I have seen installs with VWIC-1MFT-T1 cards used to terminate Frame connections. Aside from price, is there any reason to recommend a WIC-1DSU vs. a VWIC-1MFT? Is the VWIC-1MFT always a viable alternative to the WIC-1DSU?
a-vazquez
Level 6
Level 6
Cisco T1 DSU/CSU WAN Interface Card FEATURES:
T1 or fractional T1 network interface
? Wet T1 support (not available on WIC-1DSU-T1)
? N x 64 kbps or N x 56 kbps nonchannelized data rates (N = 1 to 24)
? Standards-based, including ANSI T1.403 and AT&T Publication 62411
? Full management features:
?Configuration-Capability for remote configuration via Telnet from Cisco IOS CLI.
?Monitoring-Router and DSU/CSU are manageable as a single SNMP entity; extensive DSU/CSU statistics are provided by the Cisco IOS CLI.
?Troubleshooting-Extensive loopbacks (including manual button for network line loopback), bit error rate tester (BERT) test patterns, alarm counters, and performance reports, all of which are accessible from Cisco IOS CLI. LEDs for carrier detect, loopback, and alarm functions
This URL should help you:
http://www.cisco.com/en/US/products/hw/modules/ps3129/prod_module_series_home.html
