Ping between 2 SSID
Ed Lo
I have 2 SSID broadcasting from the same radio and want to ping between them. They each have their own VLAN and DHCP pool but, I cannot ping between devices connected on each. Is there someting more I need to do in order to do this?
I'm using a 1941w router
thank you
Hello
Do you have:
-any software firewall enabed on the clietns to negate echo-reply?
-any routed acl appled on the l3 interface for these to vlans.
- Can they ping when connected to a wired connection?
-Do these SSID's have layer 7 p2p fw blocking appied on their WLC ( if the AP's are running as LAP)
res
Paul
Kind Regards
Paul
I haven't configured any firewall unless it's setup by default, no acl has been applied, I haven't tried a wired connected but I would prefer this to work wirelessly, I don't know what the last one is so I'm going to assume no.
Hello
Clients pcs ( microsoft) have software fw's and by default disable icmp messages, so it may be possible that why you cannot ping each other.
If you can ping between each client via a wired connection then this will confirm two things.
1) no software firewall is prohibiting icmp
2) no access-list on the l3 interfaces of these vlans isnt doing the same
Lastly a fw rule can be applied on a WLC where the access points connect to not allow point to point communication (p2P) for certain applications which in some case can negate communication between clients.
res
Paul
Kind Regards
Paul
