Ping fail between Cisco 4331 and ISP Router
Techworking
I have a Cisco 4331 router directly connected to an ISP router switch port.
Layer 2 is fine as I can see the mac address of the ISP router in the arp table.
There are no filters on the 4331 i directly connected interface
However at layer 3 pings are failing.
Looking at the 4331 router interface i see unknown protocol drops
sh int gi0/0/0 | i un
Last clearing of "show interface" counters 23:00:44
4743 packets output, 1774370 bytes, 0 underruns
41013 unknown protocol drop
Last clearing of "show interface" counters 23:03:35
4753 packets output, 1778066 bytes, 0 underruns
41097 unknown protocol drops
I got a user to connect a laptop to the ISP router and everything worked
the ISP are typically saying the problem is on my side
I am thinking because the link to the ISP router is connected to the built in switch port they may have DTP or something enabled. I'm sure if this would cause layer 3 connectivity to fail.
Any help with this would be greatly appreciated
6 Replies 6
Jaderson Pessoa
could you share outputs below?
show interface xxx status
show interface xx switchport
show run int xx
show int xx
Jaderson Pessoa
*** Rate All Helpful Responses ***
sh int gi0/0/0 switchport
% Gi0/0/0 is not a switchable port
sh run int gi0/0/0
interface GigabitEthernet0/0/0
description
ip address x.x.x.x 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
media-type rj45
negotiation auto
end
#sh int gi0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
Hardware is ISR4331-3x1GE, address is 50f7.22b7.5de0 (bia 50f7.22b7.5de0)
Description:
Internet address is x.x.x.x/29
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Full Duplex, 1000Mbps, link type is auto, media type is RJ45
output flow-control is off, input flow-control is off
Last input 00:00:00, output 00:00:01, output hang never
Last clearing of "show interface" counters 1d00h
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
148788 packets input, 9025528 bytes, 0 no buffer
Received 139563 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
5073 packets output, 1897964 bytes, 0 underruns
43782 unknown protocol drops
1 lost carrier, 0 no carrier, 0 pause output
Well,
I had this same issue previously and the problem as on ISP. They cannot had configured the router properly to be a P2P, they have natted the address. If you input it directly to pc it works but in the other router doesn't work. I suggest to you go ahead with your ISP.
Jaderson Pessoa
Mark Elsen
 - Give a go with arping instead.
   M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
what are you pinging, an IP address on the same subnet as your interface (usually the default gateway) ? Do the unknown drops correspond to the amount of pings you are sending ?
Hello George
Pinging default gateway
Unknown drops do not correspond with pings
