Ping fail. Cellular interface on c1861(HWIC-3G-GSM)
tc-nakajima
I am trying to ping from fa0/0(inside nat) through cellular interface(outside nat)
to 209.131.36.158(www.yahoo.com) but it fails.
As far as I see the debug output, LCP and PPP establishes successfully but fails to obtain IP address using IPCP.
And also generates TERMREQ which indicates ISP has terminated the call.
I tried changing the NAT configution but in vain.
Can anybody help me with this?
<config>
chat-script GSM "" "ATDT*99*3#" TIMEOUT 300 "CONNECT"
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface Cellular0/2/0
ip address negotiated
ip nat outside
encapsulation ppp
load-interval 30
dialer in-band
dialer idle-timeout 10
dialer string GSM
dialer-group 1
async mode interactive
no peer neighbor-route
ppp authentication chap callin
ppp chap hostname DUMMY
ppp chap password 0 DUMMY
ppp pap sent-username DUMMY password 0 DUMMY
ppp ipcp dns request
ip route 0.0.0.0 0.0.0.0 Cellular0/2/0
ip http server
no ip http secure-server
ip nat source list 10 interface Cellular0/2/0
access-list 1 permit any
access-list 10 permit 1.1.1.0 0.0.0.255
dialer-list 1 protocol ip list 1
line 0/2/0
script dialer GSM
login
modem InOut
no exec
transport input all
transport output all
autoselect during-login
autoselect ppp
<debug output>
Router#ping 209.131.36.158 source fastEthernet 0/0 repeat 3 size 64
Sending 3, 64-byte ICMP Echos to 209.131.36.158, timeout is 2 seconds:
Packet sent with a source address of 1.1.1.1
*Sep 9 10:48:23.751: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state to up
(snip)
*Sep 9 10:48:23.763: Ce0/2/0 PPP: Phase is FORWARDING, Attempting Forward
*Sep 9 10:48:23.763: Ce0/2/0 PPP: Phase is ESTABLISHING, Finish LCP
*Sep 9 10:48:23.763: Ce0/2/0 PPP: Phase is UP
*Sep 9 10:48:23.763: Ce0/2/0 IPCP: O CONFREQ [Cl.
Success rate is 0 percent (0/3)
(snip)
*Sep 9 10:48:28.163: Ce0/2/0 PPP: Sending Acct Event[Down] id[6]
*Sep 9 10:48:28.163: Ce0/2/0 IPCP: State is Closed
*Sep 9 10:48:28.163: Ce0/2/0 PPP: Phase is TERMINATING
*Sep 9 10:48:28.163: Ce0/2/0 LCP: O TERMREQ [Open] id 11 len 4
*Sep 9 10:48:30.155: Ce0/2/0 LCP: Timeout: State TERMsent
*Sep 9 10:48:30.155: Ce0/2/0 LCP: O TERMREQ [TERMsent] id 12 len 4
*Sep 9 10:48:32.171: Ce0/2/0 LCP: Timeout: State TERMsent
*Sep 9 10:48:32.171: Ce0/2/0 LCP: State is Closed
*Sep 9 10:48:32.171: Ce0/2/0 PPP: Phase is DOWN
*Sep 9 10:48:32.175: hwic_cell_async_term_ppp: PPP terminated in 3340 ms, state 1
*Sep 9 10:48:34.171: %LINK-5-CHANGED: Interface Cellular0/2/0, changed state to reset
*Sep 9 10:48:39.227: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state to down
Router#
aghaznavi
Level 5
Level 5
1 After you create a modem data profile cellular profile create command and configuring DDR on the cellular interface, send a ping from the router to a host across the wireless network.
2 If the ping fails, debug the failure by using the following debug and show commands:
debug chat
debug dialer
debug ppp negotiation
show cellular all
show interface cellular
show running-config
show ip route
jefferybjohnson
Did you ever find an solution to this problem, our company is using the verizon HWIC as well and our disconnects are coming from Verizon (Jul 20 19:15:31 UTC: Ce0/0/0 LCP: I TERMREQ [Open] id 68 len 4 ) this is the debug message the router is receiving that causes the Cell interface to disconnect. it looks like the solution is to nat and ACL the Cell interface. Did you have any luck??
thanks
Jeff
