Ping from Vlan to Router issue
Cisco_Learner25
Hi Members,
I have attached a pic/diagram with this question. My question is very simple, I just got stuck somewhere. I got two PC's, one switch and one router. PC-One got the IP address 192.168.1.20/24 , PC-Two got the IP address 192.168.1.10/24, and Router's interface got the IP 192.168.1.1/24. There is a switch in between of these three device. All can Ping each other. But when I created the VLAN's in the Switch. After that, No device can ping any of the device. I'm doing this lab in Packet-Tracer. I'm going to attach the diagram with this email. Plus, I'm to paste the run-config's of Switch and Router. Could you please have a look on the config's, and guide me that what thing i'm doing wrong. I want to Ping the Router's interface from both PC's which his 192.168.1.1/24, because subnet is same according the IP address of PC's.
By the way, by having the router in between. Should I be able to ping both PC's to each other, even they are from different VLAN's, but with the same Sabnet. Need help. Thanks
Switch#show running-config
Building configuration...
Current configuration : 1139 bytes
version 12.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
interface FastEthernet0/2
switchport trunk allowed vlan 10,20
switchport mode trunk
interface FastEthernet0/3
switchport access vlan 20
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Router#
Current configuration : 564 bytes
version 12.4
hostname Router
ip cef
no ipv6 cef
interface FastEthernet0/0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Dan Lukes
Your question is more appropriate in appropriate group of Cisco Learning Network (CLN).
Ryan Wright
I see a few issues
Your switch you need to add the Vlans 10 and vlan 20
# vlan 10
#name HR
#vlan 20
#name help desk
Router
You need vlan interfaces
#Interface vlan 10
#Ip address 192.168.1.1
#Interface vlan 20
#ip address 192.168.20.1
I would not use ip address on fast Ethernet port ..
You need to create a sub interface also known as router on a stick
