ping not working
mohammal1
hi , i have a scenario where I am trying to ping IP address 11.0.6.254 from a dell server.
on the remote host the ip address is defined like this:
ip address 11.0.6.254/24
on the dell server if I use host 11.0.6.32 as source to ping, then it works fine ... but as soon as I change it to host 11.0.6.33 the ping stops working. echo request can be seen coming on the remote node but no reply.
on the remote host:
Type    Network              Next Hop        Dist    Metric
> C     11.0.6.0/24                                    0         0
Human374
Does your Dell server has 2 NICs?
NIC 1: 11.0.6.32/24
NIC 2: 11.0.6.33/24
Could you show a ifconfig or ipconfig output?
vlan0256: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 11.0.6.250 netmask 255.255.255.0 broadcast 11.0.6.255
inet6 fe80::92e2:baff:fe69:77f5 prefixlen 64 scopeid 0x20<link>
ether 90:e2:ba:69:77:f5 txqueuelen 0 (Ethernet)
RX packets 2157072 bytes 99275776 (94.6 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 15526 bytes 1510108 (1.4 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Show us the configuration of 11.0.6.33, not 11.0.6.250.
Philip D'Ath
Double check that the subnet mask on the Dell server is 255.255.255.0.
If the subnet mask was 255.255.255.224 then you would get this problem.
