Ping response from gateway longer than from switch
RabbitSF
I am not Cisco expert so the following question might sound silly.
I have the following path,
Laptop--Access Point--Switch1(2960x)--Gateway(core 3850 switch)--Switch2(2960x)
I ping to both the Gateway and the Switch2. How come the average response from the Gateway is longer than from the Switch2?
If I run trace route to the Swtich2, the first stop is always the Gateway. I assumed the Ping should reach the Gateway first, then the Switch2.
Please correct me if my understanding is totally wrong. Thanks!
2 Accepted Solutions
Would the command " spanning-tree vlan 1-4094 priority 0 "  mess up anything except for a few secs of disconnection?
 to change things back use  " no spanning-tree vlan 1-4094 priority 0 "
Jaderson Pessoa
*** Rate All Helpful Responses ***
Hello @Jaderson Pessoa
I am not stating you are wrong in your assumptions i am just merely pointing out a possible reason why the response times are showing as they are, And as I have stated before one reason why the OP would be seeing a response time higher from the core switch as apposed to a lower response time from an access switch in front/behind the core switch (whichever way you look at it)  is possibly due to the core switch processing other stuff and its less of a priority for the core to respond to the ping
However when the same ping is sent to the access switch (via the core) this will most probably be fast switched and as such the core switch(router) will process this more quickly , now given that in this instance the source and destination is all in the same l2 domain not routing is involved so naturally the response time from the access switch which isn't as busy as the core can respond quicker then a core switch which is busy doing other things.
As @RabbitSF has confirmed no users are experiencing any issues about latency my understanding at this time is that what I have so far explained is occurring.
Kind Regards
Paul
21 Replies 21
Jaderson Pessoa
@RabbitSFhello,
I think that it is a STP issue..
Could you provide a simple design from your topology
input here output from:
show spannning-tree
Jaderson Pessoa
see attached. You might notice that the core gateway switch is NOT directly connected to the modem or firewall (MDF).
I am connected to 192.168.254.106 (the top IDF)
when I ping to the core 192.168.254.254
PING 192.168.254.254 (192.168.254.254): 56 data bytes
64 bytes from 192.168.254.254: icmp_seq=0 ttl=255 time=84.862 ms
64 bytes from 192.168.254.254: icmp_seq=1 ttl=255 time=20.926 ms
64 bytes from 192.168.254.254: icmp_seq=2 ttl=255 time=17.930 ms
64 bytes from 192.168.254.254: icmp_seq=3 ttl=255 time=26.751 ms
64 bytes from 192.168.254.254: icmp_seq=4 ttl=255 time=36.654 ms
64 bytes from 192.168.254.254: icmp_seq=5 ttl=255 time=47.100 ms
When I ping 192.168.254.107,
PING 192.168.254.107 (192.168.254.107): 56 data bytes
64 bytes from 192.168.254.107: icmp_seq=0 ttl=254 time=2.988 ms
64 bytes from 192.168.254.107: icmp_seq=1 ttl=254 time=4.024 ms
64 bytes from 192.168.254.107: icmp_seq=2 ttl=254 time=1.832 ms
64 bytes from 192.168.254.107: icmp_seq=3 ttl=254 time=1.830 ms
64 bytes from 192.168.254.107: icmp_seq=4 ttl=254 time=2.944 ms
Could your share with us your spanning-tre configuration?
show spanning-tree
show spanning-tree root
Jaderson Pessoa
Core-3850-SW1#show spanning-tree
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 32769
Address 80e8.6f31.0c00
Cost 4
Port 26 (GigabitEthernet1/1/2)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 80e8.6f3a.cf00
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Gi1/0/11 Desg FWD 4 128.11 P2p Edge
Gi1/0/15 Desg FWD 4 128.15 P2p Edge
Gi1/0/16 Desg FWD 4 128.16 P2p Edge
Gi1/0/19 Desg FWD 19 128.19 P2p Edge
Gi1/0/20 Desg FWD 19 128.20 P2p Edge
Gi1/0/23 Desg FWD 4 128.23 P2p Edge
Gi1/0/24 Desg FWD 4 128.24 P2p Edge
Gi1/1/2 Root FWD 4 128.26 P2p
Gi1/1/3 Desg FWD 4 128.27 P2p
Gi2/1/1 Desg FWD 4 128.89 P2p
Po1 Desg FWD 3 128.2027 P2p
Po2 Desg FWD 3 128.2028 P2p
Po10 Desg FWD 3 128.2036 P2p
VLAN0010
Root ID Priority 32778
Cost 4
Bridge ID Priority 32778 (priority 32768 sys-id-ext 10)
Aging Time 300 sec
Gi2/0/17 Desg FWD 19 128.81 P2p Edge
Gi2/0/18 Desg FWD 19 128.82 P2p Edge
VLAN0020
Root ID Priority 32788
Cost 4
Bridge ID Priority 32788 (priority 32768 sys-id-ext 20)
Aging Time 300 sec
Gi1/0/13 Desg FWD 4 128.13 P2p Edge
Gi1/0/14 Desg FWD 4 128.14 P2p Edge
Gi2/0/1 Desg FWD 4 128.65 P2p Edge
Gi2/0/2 Desg FWD 4 128.66 P2p Edge
Gi2/0/3 Desg FWD 19 128.67 P2p Edge
Gi2/0/6 Desg FWD 19 128.70 P2p Edge
Gi2/0/7 Desg FWD 19 128.71 P2p Edge
Gi2/0/21 Desg FWD 19 128.85 P2p Edge
Gi2/0/24 Desg FWD 19 128.88 P2p Edge
VLAN0100
Root ID Priority 32868
Cost 4
Bridge ID Priority 32868 (priority 32768 sys-id-ext 100)
Aging Time 300 sec
VLAN0253
Root ID Priority 33021
Cost 4
Bridge ID Priority 33021 (priority 32768 sys-id-ext 253)
Aging Time 300 sec
VLAN0254
Root ID Priority 33022
Cost 4
Bridge ID Priority 33022 (priority 32768 sys-id-ext 254)
Aging Time 300 sec
VLAN0255
Root ID Priority 33023
Cost 4
Bridge ID Priority 33023 (priority 32768 sys-id-ext 255)
Aging Time 300 sec
VLAN0256
Root ID Priority 33024
Cost 4
Bridge ID Priority 33024 (priority 32768 sys-id-ext 256)
Aging Time 300 sec
Core-3850-SW1#show spanning-tree root
Root Hello Max Fwd
Vlan Root ID Cost Time Age Dly Root Port
VLAN0001 32769 80e8.6f31.0c00 4 2 20 15 Gi1/1/2
VLAN0010 32778 80e8.6f31.0c00 4 2 20 15 Gi1/1/2
VLAN0020 32788 80e8.6f31.0c00 4 2 20 15 Gi1/1/2
VLAN0100 32868 80e8.6f31.0c00 4 2 20 15 Gi1/1/2
VLAN0253 33021 80e8.6f31.0c00 4 2 20 15 Gi1/1/2
VLAN0254 33022 80e8.6f31.0c00 4 2 20 15 Gi1/1/2
VLAN0255 33023 80e8.6f31.0c00 4 2 20 15 Gi1/1/2
VLAN0256 33024 80e8.6f31.0c00 4 2 20 15 Gi1/1/2
VLAN0256
Cost 4
Aging Time 300 sec
All of your vlans has a other switch as root bridge, it is correctly in your topology?
Jaderson Pessoa
Jaderson,
Thanks much for looking into this with me! But I don't know how I can answer your question because I am not a Cisco expert and the network was not set up by me. I am not familiar with all these Cisco routing protocol either. I know STP is a big topic and it will take me a while to learn and understand.
Out IT Consultant set up all the Cisco switches and the whole network. They did tell me the following:
"..... One other thought that crossed my mind is the loop you have in your network as well. You have lower school building with Internet connection with VLAN's etc. That connection then is carried to the firewall, then trunked over the fiber to the core switch. That same trunk also carries ALL other vlans back to lower school building...."
If you look at the network diagram I uploaded, you can see the lower school building is at the bottom level where the MPOE is located. My laptop is the at the 2nd building on the top IDF. The core switch is located at the 3rd building in the middle IDF. I don't know if that helps you understand our topology.
One more thing, if you look at the network diagram I uploaded, you will notice there are two core 3850 switches. They are actually stacked together creating a loop for redundancy if I understand correctly.
Are you facing any slowness issue? Did you enable any QoS? I think the best way to share traceroute command output so we can understand actually place where we were having an issue and will look into the configuration also.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
right,
Could you check who switch has this mac address? 80e8.6f31.0c00 (just to confirm if it is a STP issue).
you can check it using " show version " in end of the page you will see mac address
Jaderson Pessoa
Hello
FYI @Jaderson Pessoa  easiest way to check the base mac address of a switch
show version | in Base
Kind Regards
Paul
@paul driver Hello,
I know it, but i'm trying show to @RabbitSF how many information he can see on this command. He is not a expert on network or managerment switches.
Jaderson Pessoa
Jaderson, the mac address 80e8.6f31.0c00 is the access switch (192.168.254.107) which is connected directly to the firewall. The path is like below,
Cloud--Comcast Modem--Firewall--Access Switch(80e8.6f31.0c00)--Core Switch--other Access Switches--Clients
@RabbitSF well, i'm still think that your STP topology is the problem.
Let me try explain.
YOUR CORE HAS ALL VLANS AND SVI CREATED ON ITSELF, BUT IT IS NOT ROOT FOR ANY VLANS, THE ROOT BRIDGE FOR YOUR VLANS IS A SWITCH ACCESS 2960X WITH IP ADDRESS 192.168.254.107.
ON YOUR 3850 (SWITCH CORE) run this command below
obs: this will disconnect all comunication for few seconds
Jaderson Pessoa
Hello
@Jaderson Pessoa
the stp root at present is in front of the core switch and also it has another switch interconnected to it which isn’t connected to the core so the placement of the root as it is is viable.as that switch is central between the core its own connecting switches  and the router
Kind Regards
Paul
