Pix site to site vpn
pimpcatccna
Hi Guys just a quick question. we have two sites that are connected via a leased line however we are currently moving office and need Internet connectivity while a new leased line is installed. to do this we will use ADSL for the month that it is going to take and i would like to use a ipsec vpn between both sites while waiting for the leased line. my question is how easy would it be to create a ipsec site to site vpn between a site using a 800 series adsl router and our cisco 515 pix?
the reason i ask is i have not purchased the 800 series router yet as i want to be sure that it will work
Regards P Lawrence
Latchum Naidu
Hi Lawrence,
You can setup a site to site IPsec tunnel between your 800 (IOS router) and pix. I have the setup for one of my customer.
You need to make sure that 800 router with K9 bundel image example: c870-advipservicesk9-mz.124-15.T1.bin
Now you can create a vpn tunnel for temporary or for permanent.
Please rate the helpfull posts.
Naidu.
