PLC Device Visible on LAN, but not on WAN
lukepreston
Hello All,
I am having trouble connecting a PLC device to the Wider network.
I have set it up with an IP address, correct gateway and subnet mask.
It is visible on the LAN through a 2950 Series switch.
However it can not be seen outside of this, then when pinged through the connected server it cannot be seen.
the settings are as follows
interface GigabitEthernet0/1
description Customer LAN
ip address 160.222.35.225 255.255.255.0 secondary
ip address 10.28.215.25 255.255.255.252 secondary
ip address 160.222.237.225 255.255.255.0
ip access-group ethernet-in in
ip flow ingress
ip flow egress
ip tcp adjust-mss 1420
duplex full
speed 100
What can block connection at this point?
mfurnival
Level 4
Level 4
What is a PLC device?
I think a basic diagram and the full router and switch config would be a big help here.
