Please check my BGP configuration
DellBananaALK
This is a odd setup ISP supposed connect to same router ISP
No OSPF and static router
R1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Ethernet0/0
ip address 192.168.1.2 255.255.255.252
duplex auto
bfd interval 50 min_rx 50 multiplier 5
interface Ethernet0/1
ip address 172.16.1.1 255.255.255.252
duplex auto
interface Ethernet0/2
no ip address
shutdown
duplex auto
interface Ethernet0/3
ip address 172.16.10.1 255.255.255.248
standby 1 ip 172.16.10.3
standby 1 priority 105
standby 1 preempt
standby 1 track 1 decrement 20
duplex auto
router bgp 200
bgp router-id 1.1.1.1
bgp log-neighbor-changes
neighbor 2.2.2.2 remote-as 200
neighbor 2.2.2.2 update-source Loopback0
neighbor 192.168.1.1 remote-as 100
neighbor 192.168.1.1 fall-over bfd
address-family ipv4
network 1.1.1.1 mask 255.255.255.255
network 100.100.0.0 mask 255.255.0.0
network 172.16.10.0 mask 255.255.255.0
neighbor 2.2.2.2 activate
neighbor 2.2.2.2 next-hop-self
neighbor 2.2.2.2 soft-reconfiguration inbound
neighbor 192.168.1.1 activate
neighbor 192.168.1.1 soft-reconfiguration inbound
neighbor 192.168.1.1 route-map to-in-route-map in
neighbor 192.168.1.1 route-map to-out-route-map out
exit-address-family
no ip http server
no ip http secure-server
ip route 2.2.2.2 255.255.255.255 172.16.1.2
ip route 100.100.0.0 255.255.0.0 Null0
ip route 172.16.10.0 255.255.255.0 Null0
ip prefix-list to-out-prefix seq 10 permit 245.45.24.0/24
ip prefix-list to-out-prefix seq 20 permit 37.23.65.87/32
ip prefix-list to-out-prefix seq 30 permit 100.100.0.0/16
ipv6 ioam timestamp
route-map to-in-route-map permit 10
set local-preference 200
route-map to-out-route-map permit 10
match ip address prefix-list to-out-prefix
route-map to-out-route-map permit 20
R2
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip address 192.168.1.66 255.255.255.252
duplex auto
ip address 172.16.1.2 255.255.255.252
duplex auto
no ip address
shutdown
duplex auto
ip address 172.16.10.2 255.255.255.248
standby 1 preempt
duplex auto
router bgp 200
bgp router-id 2.2.2.2
neighbor 1.1.1.1 remote-as 200
neighbor 192.168.1.65 remote-as 100
address-family ipv4
network 2.2.2.2 mask 255.255.255.255
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 next-hop-self
neighbor 1.1.1.1 soft-reconfiguration inbound
neighbor 192.168.1.65 activate
neighbor 192.168.1.65 soft-reconfiguration inbound
neighbor 192.168.1.65 route-map to-out-route-map out
exit-address-family
no ip http server
ip route 1.1.1.1 255.255.255.255 172.16.1.1
ip prefix-list to-out-prepend seq 5 permit 100.100.0.0/16
ip prefix-list to-out-prepend seq 10 permit 1.1.1.1/32
ip prefix-list to-out-prepend seq 15 permit 2.2.2.2/32
ip prefix-list to-out-prepend seq 20 permit 172.16.10.0/24
ipv6 ioam timestamp
match ip address prefix-list to-out-prepend
set as-path prepend 200 200 200
route-map to-out-route-map permit 30
ISP
neighbor 192.168.1.2 remote-as 200
neighbor 192.168.1.2 fall-over bfd
neighbor 192.168.1.66 remote-as 200
neighbor 192.168.10.2 remote-as 100
address-family ipv4
network 3.3.3.3 mask 255.255.255.255
network 30.30.0.0 mask 255.255.0.0
neighbor 192.168.1.2 activate
neighbor 192.168.1.2 default-originate
neighbor 192.168.1.2 soft-reconfiguration inbound
neighbor 192.168.1.66 activate
neighbor 192.168.1.66 default-originate
neighbor 192.168.1.66 soft-reconfiguration inbound
neighbor 192.168.10.2 activate
neighbor 192.168.10.2 next-hop-self
neighbor 192.168.10.2 soft-reconfiguration inbound
exit-address-family
M02@rt37
Hello @DellBananaALK
Configurations seem to be good.
Using the Null0 interface for route summarization is good... However, be cautious with using it for the whole subnet '172.16.10.0/24'. It might be better to use a more specific route to avoid accidentally blackholing legitimate traffic.
Best regards
I'm looking for best practices and any recommendation to or changes ?
I see your topolgy but I dont know where is LO connect abd prefix.
Also how you use bgp multihop and fall over bfd? Yoh need bfd multihop
MHM
ISP is not far,  it's very close by and I think less few miles or walking distance
It's safe to use
I added the second route-map and add permit and made it blank so it allow everything doesn't make any changes so much it's allowing everything
Question was route-map with access-list you don't need a second route-map to allow?
it's different from prefix-list
