show policy-map interface
Dears,
I have Cisco IOS-XE and want to see the output for the command (show policy-map interface) using Yang model to check the traffic byte for each class inside the policy .. so I used the model (Cisco-IOS-XE-policy). Still, i can't find the output for the mentioned command. Kindly advice.
is there any update plz ..
hello, did you find the solution?
