11-26-2024 06:56 AM
I have two /24 IP blocks: 192.168.83.0/24 and 192.168.82.0/24. I am using two ISPs with BGP for internet connectivity.
Currently, all uploads are handled by one ISP, while downloads are split between the two ISPs.
now I want to configure it so that both uploads and downloads for 192.168.83.0/24 go through ISP 1, and both uploads and downloads for 192.168.82.0/24 go through ISP 2.
Here are the details:
• ISP 1: 10.0.0.10/30 (P2P IP: 10.0.0.9)
• ISP 2: 20.0.148.2/30 (P2P IP: 20.0.148.1)
I want:
• 192.168.83.0/24 to use 10.0.0.9 for both uploads and downloads via ISP 1.
• 192.168.82.0/24 to use 20.0.148.1 for both uploads and downloads via ISP 2.
i am using ASR 1004
Thanks in advance
12-07-2024 07:59 AM
Thanks for the update. Glad you have found a solution that works for your environment.
12-07-2024 12:09 AM
Thank you for following up. If you havent already I would recommend flow monitors so you can verify synchronous routing for each subnet. The return traffic will need to be monitored to ensure it is preferring ISP2.
