Please help me with this Router Memory
WizIT
Please refer the output of command
show version
show flash and explain me,
http://blog.erealmedia.com/?p=23
These output are taken from a Generic Router on Packet Tracer 4.1 (cisco simulator)
Can you kindly explain different memory I have labelled here.
1. How I know how much RAM, ROM, NVRAM & Flash memory this router has?
2. Is labelled E and C are both flash memory? IF then why different value?
3. What the meaning of these two memory -60416K/5120K, (in label A).
royalblues
Level 10
Level 10
60416K/5120K - The RAM the device has i.e 64MB
B in your figure lets you know the NVRAM i.e the amount used to save the startup config
C&E should be same and gives you the amount of flash you have. This could be an error in the simulator
Narayan
Thanks Narayan
