Please help not ping to fram-relay
Kimjohn
I set fram-relay and rip-eigrp redistribute
but not ping 163.181.0.2 to 211.10.10.1
please help
2 Accepted Solutions
there is no EIGRP process configured on Router5, so you cannot redistribute anything.
The only way for the two routers to talk (163.181.0.2 and 211.10.10.1 to be able to ping each other) is by adding the static routes below. You can also redistribute the static route in RIP on Router5, and in EIGRP on Router7, so all networks can reach each other.
Router5
ip route 211.10.10.0 255.255.255.0 Serial0/2/0
Router7
ip route 163.181.0.0 255.255.0.0 Serial0/2/0
The revised file (saved in Packet Tracer version is attached.
Hello
You were had incorrect FR mappings as such eigrp peering wouldn’t establish as you were not allowing broadcast between the rtrs.
Also, you had no redistribution between eigrp and rip, Lastly rtr 6 has no ip addressing whatsoever.
Review working PKt with correct FR and rip/eigrp redistribution without any static routing
Kind Regards
Paul
8 Replies 8
Router5
Router7
Hello
Kind Regards
Paul
@paul driver
Just out of curiosity...how did you establish an EIGRP neighborship between Router5 and Router7, with EIGRP not configured at all on Router5 ?
And no RIP configured at all on Router7...so redistribution would never work anyway, because there is nothing to redistribute.
I guess we would need to see the requirements for this network more in detail...
Hello @Georg Pauwen
Rtr 5 had rip with a redistribution for eigrp but not eigrp stanza , Rtr 7 had eigrp stanza with a rip redistribution statement so it seems the OP was trying to establish mutual redistribution but couldn’t achieve it, and the reason for that was missing eigrp on rtr5 and the incorrect FR on both rtrs to allow broadcast.
Kind Regards
Paul
@paul driver
It's probably me, or maybe it's because it is too early in the morning, but I am lost, as I don't see how you can mutually redistribute between EIGRP and RIP without both protocols actually running on the router. Or does Frame Relay make that possible ? I don't remember exactly, since it is a rather ancient technology...
Either way, I think that network needs a lot of 'rework', and I don't know what the exact requirements are. I was simply trying to answer the original question, which was why both routers could not ping each other. Maybe OP can provide the full requirements/specs of this topology...
Hello @Kimjohn
Glad to hear and thank you the clarification.
@Georg Pauwen
As i said "
Rtr 5 had rip with a redistribution for eigrp but not eigrp stanza , Rtr 7 had eigrp stanza with a rip redistribution statement"
So i applied eigrp on R5 so the this then had rip AND eigrp running , this is then was the rtr perfroming the mutual redistribution
Kind Regards
Paul
@paul driver
Exactly, you are right. So both the static routing or adding EIGRP to R5 and then redistribute into RIP work. My Chinese is not that good, so I cannot read what exactly this topology is supposed to look like.
Thank you very much I will study more. redistribution
