Please help to configure 871W Router for internet connection!
David Belmont
Hi, everybody!
I've just started styding for CCNA, so I'm totaly new to Cisco stuff. Bought a router 871W recently and spent two days straight trying to configure internet connection with no luck! I use console port to do the configs and SDM/CCP. Would be greateful if somebody could tell me how to do simple internet connection configs. I googled everything but it's still confusing. I can't assing any IP to FA ports 0 - 3. I used VLAN instead. But all tutorials use FA0 and when I try to assign an IP to FA0 it gives me some L2 can't be assigned or something... :/ And I'm also confused what IP address should I use for WAN.
I plugged the cable from Modem to PC's LAN port and wrote down some IP addresses which I think I'll have to use to configure the router for internet connection. And here they are:
ISP IP: 76.114.54.255
SUBNET: 255.255.248.0
GATEWAY: 76.114.48.1
DHCP: 69.252.97.4
DNS: 75.75.75.75
         75.75.76.76
If you can, please help! Thanks!
4 Accepted Solutions
hi david,
seems like your 871w can't get any dynamic IP: %Unknown DHCP problem.. No allocation possible
could you ask your ISP to perform a reset/clear MAC add and try again?
also, kindly post lastest 'show run'
edit: just saw you've updated your screenshot. could you add command under FE4
mac-add 0001.4af9.8b83
Hello David, the MAC address on FE4 should be this: 001f.ca6b.d8c8
As this is the MAC address of the router itself. I could see that you had configured your interface to have a mac of the Sony device I think. But we do not want that.
Try changing it to the mac mentioned above and see if it works.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hello, your mac address for the actual router interface is displayed in show interface fe4
show int fa4
FastEthernet4 is up, line protocol is up
Hardware is PQUICC_FEC, address is 0001.4af9.8b83 (bia 001f.ca6b.d8c8)
Here we can see that the BIA (burnt in address) is a MAC address of a Cisco device - being the router itself. However, because you have configured it to use the MAC address of the Sony device the router is now using that to communicate with the modem. 0001.4af9.8b83 belongs to your sony device. So the router will see the MAC address of the Sony device, but it may get confused because its own MAC address is configured to be the same!
The MAC address should be FE4 so it can get an IP from the modem as 'itself' and not appear to be the Sony device.
It's working with PC1 because you're not using the MAC address of PC1, so I think this is what's happening! :-)
Router(config-if)#mac-address 001f.ca6b.d8c8
So please try this and see if there are any changes in the results
Hope this helps.
Hello David, thanks for this - sorry I was a bit unclear, I wanted to see what happens when you use your routers mac address instead - do you see its mac address on the motorola?
But before we do this, I want you to try this for us please:
interface FastEthernet4
no mac-address 0001.4af9.8b83
no ip address dhcp client-id FastEthernet4
ip dhcp client-id hex 001fca6bd8c8
ip dhcp client hostname Point38
ip address dhcp
Then shut the interface down, then bring it back up after 5 seconds or so.
If you configure a Cisco router as a DHCP client, it may use a weird client-id in its DHCP requests. Instead of using the interface MAC address as the client ID (as most workstations do), the client ID is the string 'cisco-dotted.mac.ascii-ifname' where the dotted.mac.ascii is the interface MAC address in ascii and the ifname is the short interface name.
So give this a go - I tried this between two cisco routers, I know its not the same tests but I saw different behaviour with these commands.
Hope this helps
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
37 Replies 37
johnlloyd_13
Level 9
Level 9
hi david,
did you set your PC to auto obtain an IP?
if it is, probably the ISP assigns a dynamic IP, configure FE4 as below.
interface fa4
ip address dhcp client-id fastethernet 4
FE 0-3 are layer 2 only ports and under VLAN 1 by default. configure SVI/LAN gateway IP with your preferred private IP address (google or refer RFC 1918).
interface vlan 1
ip address
you'll need DHCP and NAT enabled for other LAN clients/hosts to surf the web.
ip dhcp pool
network /SUBNET MASK
default-router
dns-server 75.75.75.75 75.75.75.76
int fa4
ip nat outside
int vlan1
ip nat inside
access-list 1 permit
ip nat inside source list 1 fa4 overload
add a static default route so that clients can go to the web. remember to save your config ("copy run start" for CCNAs)
ip route 0.0.0.0 0.0.0.0 dhcp
write memory
Thanks for quick reply John!
I've tried to punch in your configs but now sure if I've done it right due to lack of subnetting knowledge... Yes, I set my PC to obtain IPs by using DHCP. I can give it a static IP if necessary. Currently I'm able to ping the router from pc and pc from the router. But still no internet connection. I've tried to test FastEthernet4 with CCP and it gave me this:
Checking interface IP address..                               |         Failed
No IP address for the interface has been obtained. The interface is configured to obtain an IP address through DHCP. The remote end may not be configured with a DHCP server or the DHCP pool may be empty.
But I'm not sure if I can trust this software just because yesterday connection was successful and still there was no internt connection.
___________________________________________________________________________________________________
Here are my Router configs:
Router#show run
Building configuration...
Current configuration : 2951 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool DHCP_POOL
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 75.75.75.75 75.75.76.76
crypto pki trustpoint TP-self-signed-2115742889
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2115742889
revocation-check none
rsakeypair TP-self-signed-2115742889
crypto pki certificate chain TP-self-signed-2115742889
certificate self-signed 01
  3082023F 308201A8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32313135 37343238 3839301E 170D3131 30393037 32313133
  30335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 31313537
  34323838 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CD81 CACC71A5 2A0A35C4 5A6598E9 A78B8167 11D2EA22 EA7C6B63 3D12AD5C
  671E5896 D3BA86CD AF2F9230 A8C1DBC9 65D529EC F9E44975 175A6554 EE3CE29E
  C3B6AB9E 2FDD5A55 4D1249CC 37101125 F55BC25D D9FF17C3 282DA1EF A2BA56F4
  3060E197 5C963A39 4ED08A8D C2CFB556 899D5D50 1FFF9F59 A9243C46 3F501566
  60950203 010001A3 67306530 0F060355 1D130101 FF040530 030101FF 30120603
  551D1104 0B300982 07526F75 7465722E 301F0603 551D2304 18301680 14EEE106
  6C3A65DC E574C5A4 FEAD137B 2F950691 17301D06 03551D0E 04160414 EEE1066C
  3A65DCE5 74C5A4FE AD137B2F 95069117 300D0609 2A864886 F70D0101 04050003
  81810057 9E0A85A2 274C3B42 2D79FC55 CF70C7D0 AB3E3ABB 06310C37 80569306
  6C94D8D3 DAB3FFE2 D743FD3F DAF8CB5C DEF84219 07F942F9 CA2BF41B A5471257
  C9B12A20 F448B577 E162BDBC 6DCDBD41 E40AB3D2 AE5B50E9 713BB2D5 54B32602
  A06FFB2C BB96DF24 3B258827 BDFE4AFA 811912C1 37FFDAC8 AF1E0213 5A0A06C6 4BA6D5
  quit
username Point38 privilege 15 password 0 Terminal38
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
ip nat inside
ip classless
ip http server
ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
alias exec s show ip int brief
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
PC Configs assigned by DHCP:
IP: 192.168.1.2
SUBNET: 255.255.255.0
GATEWAY: 192.168.1.1
DHCP Server: 192.168.1.1
DNS Servers: 75.75.75.75
                    75.75.76.76
Please have a look when you'll have a chance. Thanks!
hi david,
your config looks ok and i believe you're on track.
ccp is not very flexible when it comes to troubleshooting. was internet working prior?
could you post show ip interface brief?
try rebooting cable modem (advisable to remove/insert power source) and do a shut/no shut on FE4. give it a try and let me know.
Nope, there was no internet connection on this router. I've a cheap Belkin $30 and it works just fine, plug the cable and that's it. Rebooted, turned off and on FA4.
Router#s
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
FastEthernet4              unassigned      YES DHCP   up                    up
Dot11Radio0                unassigned      YES TFTP   administratively down down
Vlan1                      192.168.1.1     YES NVRAM  up                    up
NVI0                       unassigned      YES unset  up                    up
Virtual-Dot11Radio0        unassigned      YES TFTP   administratively down down
Can you do this:
config t
no service timestamp debug
logging buffered debug 100000
do debug dhcp detail
int fa4
shut
no shut
do sh log
and post output here
then disable this debug: do undebug  all
Alain
debug dhcp helped a lot. will add this command under my tool belt.
+5 alain!
Hello, I just wanted to point out the 'ip route 0.0.0.0 0.0.0.0 dhcp' is that correct?
When you pick up an IP address from DHCP the default router option is given out with that lease and the router automatically adds a static default route in place towards its default gateway.
Not sure about the dhcp address not being given out.... Could we simply try 'ip address dhcp' only?
Hope this helps
Could you also kindly show us the output from 'show interface fa4' please?
hi bilal,
you've got a point there and could be right. i just put the command there out on top of my head.
OP can alternatively use 'import all' on the DHCP option.
david,
could you try removing the static default route and add in import all on DHCP.
also, perform 'renew dhcp f4' and the debug as per alain's advice to help us further dignose.
no ip route 0.0.0.0 0.0.0.0 dhcp
import all
Hi john,
import all and ip route 0.0.0.0 0.0.0.0 dhcp are not related to my best knowledge, what import all does is use DHCP infos received on the client side and advertise it on the server side to the clients.
Alain
hi alain,
last time i've checked it works with both static route pointing to dhcp and with import all enabled.
maybe OP can play around and try which one works.
Oh boy, what a nightmare.
Have tried everything above, hope it's not hardware's fault.
Stpep 1 per Alain: do debug dhcp detail (it was a nice show btw.)
                           (Haven't done any changes since the last time.)
Router(config)#no service timestamp debug
Router(config)#logging buffered debug 100000
Translating "buffered"...domain server (255.255.255.255)
% Invalid input detected at '^' marker.
Router(config)#do debug dhcp detail
DHCP client activity debugging is on (detailed)
Router(config)#int fa4
Router(config-if)#shut
Router(config-if)#no shut
Router(config-if)#do sh log
DHCP: Release IPL called for interface FastEthernet4 in state 9
RAC: DHCP stopped on interface FastEthernet4
DHCP: DHCP client process started: 10
RAC: Starting DHCP discover on FastEthernet4
DHCP: Try 1 to acquire address for FastEthernet4
DHCP: allocate request
DHCP: zapping entry in DHC_PURGING state for Fa4
DHCP: deleting entry 83578C6C 0.0.0.0 from list
Temp IP addr: 0.0.0.0  for peer on Interface: FastEthernet4
Temp  sub net mask: 0.0.0.0
   DHCP Lease server: 0.0.0.0, state: 9 Purging
   DHCP transaction id: 156
   Lease: 0 secs,  Renewal: 0 secs,  Rebind: 0 secs
   Next timer fires after: 00:00:23
   Retry count: 0   Client-ID: 001f.ca6b.d8c8
   Client-ID hex dump: 001FCA6BD8C8
   Hostname: Router
DHCP: new entry. add to queue, interface FastEthernet4
DHCP: SDiscover attempt # 1 for entry:
   DHCP Lease server: 0.0.0.0, state: 1 Selecting
   DHCP transaction id: 1146
   Next timer fires after: 00:00:04
   Retry count: 1   Client-ID: 001f.ca6b.d8c8
   Hostname: Router
DHCP: SDiscover: sending 275 byte length DHCP packet
DHCP: SDiscover 275 bytes
            B'cast on FastEthernet4 interface from 0.0.0.0
DHCP: SDiscover attempt # 2 for entry:
   Retry count: 2   Client-ID: 001f.ca6b.d8c8
   Hostname: Router
DHCP: SDiscover attempt # 3 for entry:
   Retry count: 3   Client-ID: 001f.ca6b.d8c8
   Hostname: Router
DHCP: QScan: Timed out Selecting state%Unknown DHCP problem.. No allocation possible
DHCP: Waiting for 5 seconds on interface FastEthernet4
DHCP: Try 2 to acquire address for FastEthernet4
   Next timer fires after: 00:00:26
   Hostname: Router
   DHCP transaction id: 1147
   Hostname: Router
   Hostname: Router
   Hostname: Router
Syslog logging: enabled (1 messages dropped, 1 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 566 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: disabled, xml disabled,
                    filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
No active filter modules.
    Trap logging: level informational, 34 message lines logged
Router(config-if)#do undebug  all
Step 2 per Bilal:
ip address dhcp (didn't help)
Router#show interface fa4
  Hardware is PQUICC_FEC, address is 001f.ca6b.d8c8 (bia 001f.ca6b.d8c8)
  Internet address will be negotiated using DHCP
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1000 bits/sec, 3 packets/sec
     109 packets input, 6540 bytes
     Received 109 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     7 packets output, 3185 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 lost carrier, 0 no carrier
Router#
Step 3 per John: when renewing DHCP I got this message: Not in Bound state.
somebody had the same problem over here: https://supportforums.cisco.com/thread/25334
Router#conf t
Router(config)#no ip route 0.0.0.0 0.0.0.0 dhcp
Router(config)#ip dhcp pool DHCP_POOL
Router#renew dhcp fa4
Not in Bound state.
Router#s
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
DHCP: Release IPL called for interface FastEthernet4 in state 1
DHCP: deleting entry 834DBAB0 0.0.0.0 from list
   DHCP transaction id: 2B
   Next timer fires after: 00:00:31
   Hostname: Router
   DHCP transaction id: 1CD4
   Hostname: Router
   Hostname: Router
   Hostname: Router
DHCP: deleting entry 833F6198 0.0.0.0 from list
   Hostname: Router
   DHCP transaction id: 1CD5
   Hostname: Router
   Hostname: Router
   Hostname: Router
DHCP: Waiting for 10 seconds on interface FastEthernet4
DHCP: Try 3 to acquire address for FastEthernet4
DHCP: deleting entry 837DC944 0.0.0.0 from list
   Next timer fires after: 00:00:21
   Hostname: Router
DHCP: Received a BOOTREP pkt Not for us..:  xid: 0x2DBE858E
DHCP: Received a BOOTREP pkt Not for us..:  xid: 0x2DBE858E%Unknown DHCP problem.. No allocation possible
DHCP: Waiting for 15 seconds on interface FastEthernet4
    Console logging: level debugging, 288 messages logged, xml disabled,
                     filtering disabled
                     filtering disabled
                    filtering disabled
    Trap logging: level informational, 30 message lines logged
All possible debugging has been turned off
Router(config-if)#
DHCP: Received a BOOTREP pkt Not for us..:  xid: 0x14791A2A
Router(config-if)#exit
Maybe this might be helpful:
Router#show ip route
Gateway of last resort is not set
C    192.168.1.0/24 is directly connected, Vlan1
And once again the print screen of my other router configs where internet works. Maybe it is possible to use these settings instead of DHCP?
P.S. I don't know if it matters or not but my Modem's ip is 192.168.100.1 should've tried to ping it I guess...
hi david,
Wow, I think adding MAC to FA4 gid the trick! According to the ping from the router there is internet connection! But can't tell for sure, another problem appeared like I can't ping my router form PC and PC from the router!?
Latest show run:
Router#s
FastEthernet4              76.114.54.255   YES DHCP   up                    up
Router#sh
Router#show run
Current configuration : 2959 bytes
version 12.4
no service pad
no service timestamps debug uptime
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
   import all
  quit
ip nat outside
duplex auto
speed auto
no ip address
shutdown
station-role root
interface Vlan1
ip nat inside
ip classless
ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Router#show int vlan1
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is 001f.ca6b.d8be (bia 001f.ca6b.d8be)
  Internet address is 192.168.1.1/24
  Last input 00:00:01, output never, output hang never
  5 minute input rate 1000 bits/sec, 1 packets/sec
     3681 packets input, 329981 bytes, 0 no buffer
     Received 1697 broadcasts, 0 runts, 0 giants, 0 throttles
     682 packets output, 48756 bytes, 0 underruns
     0 output errors, 1 interface resets
Router#show int fa4
  Internet address is 76.114.54.255/21
  5 minute input rate 3000 bits/sec, 8 packets/sec
  5 minute output rate 0 bits/sec, 1 packets/sec
     9332 packets input, 649471 bytes
     Received 8421 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     1221 packets output, 217311 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
Router#ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/34/52 ms
Router#ping www.google.com
Translating "www.google.com"...domain server (75.75.75.75) [OK]
Sending 5, 100-byte ICMP Echos to 74.125.239.83, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/44/56 ms
Router#
