Please suggest a suitbale router
abdulrafeeque
I would like to have your suggestion for purchasing a router.
We have 7 branches, required to connect the router, All links are ethernet twisted pair.
In addition of above interfaces, we need two Gigaethernet interfaces too.
Which may required adquate processing power and memmory also
Kindly suggest a suitable router.
Latchum Naidu
Hi Abdul,
I would suggest a 2951 is the better one for your scenario.
It will have 3 GigabitEthernet interfaces and 1 vpn module
It also have 255K NVRAM and 254464K CompactFlash.
I have this in my DC which connected over 30 locations and 20 site to site vpn's and 15 client vpn's.
Please rate if this helps you :-)
Naidu.
jc84_
Hi Abdul,
Selecting a router can take you through a number of different selection criteria (ie. cost, performance, module capacity ect...)
One of the most important, IMHO, is router performance.  If your performance requirements (ie. throughput) is 1Mbps then why go with a 2921, 2951 ect..
Here is a link to a Cisco router performance guide...
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
Rate if this helps
