%PM-4-ERR_DISABLE: bpduguard error detected on Gi1/0/45, putting Gi1/0/45 in err-disable state
eferland
Is this due to my new switch being plugged into another switch a old linksys?
Hello Eric,
An old linksys. Shoud I disable BPDUGuard on that port?
Yes - disable both PortFast and BPDUGuard on that port. Be careful about disabling both of them.
Best regards,
Peter
Peter Paluch
Eric,
This message tells you that the device connected to the Gi1/0/45 port of your Catalyst is sending BPDUs while the Gi1/0/45 port is supposed to be connected to an end device and is expected to never receive BPDUs. What is connected to the Gi1/0/45? Is it a switch that runs STP?
Best regards,
Peter
Hello Eric,
Best regards,
Peter
