Can I copy a config from one switch to another?
eferland
I would need to change the IP and name but I want the vlans, qos ...... to all be the same. Is that posible?  They are all 2960s.
I'm configuring a new switch and getting a "
%PM-4-ERR_DISABLE: bpduguard error detected on Gi1/0/45, putting Gi1/0/45 in err-disable state"
Im going to try and figure out the error but if I run short on time can I just grab the config from one of the other switches?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Sure. (Athough that might not change your BPDUGuard issue.)
Joseph W. Doherty
Disclaimer
Posting
Hmm you might be right. How would I do it make and copy?
Ill start another thread about the err
