POE ports
eng_adel273
I some of the POE ports are not working like port gi1/0/12 .
I tried to  shutdown &  no shutdown , but also not working. as in attached file
also Checked command "show power inline " and check the used/remaining power , it was 80/750
please help
23 Replies 23
Leo Laohoo
Post the complete output to the following commands:
1. sh version; and
2. sh post
Kindly find the txt file contains the result of commands
2960X with 15.0(2a)EX5. Right, so if you move this device to a different port does it work or not?
I used any ports on the switch , it is working
and some ports are not working
Try upgrading the firmware first.
What is the device model?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
2960 series
make sure that 'power inline never' is not configured on the ports that are not working. You can also try to set the power consumption manually:
interface GigabitEthernet1/0/12
power inline consumption 7000
In addition, post the output of:
debug ilpower port
debug ilpower powerman
kindly find the attached  results
Port 34 is not working POE
Post the complete output to the command "sh interface Gi1/0/34 controll".
Kindly find the attached result as you request
If it works on any other port, port 34 could be faulty. You might want to contact TAC and organize an RMA.
I have Many Ports ( 10 Ports )  Like that
All from the same switch?
