POE ports
eng_adel273
I some of the POE ports are not working like port gi1/0/12 .
I tried to  shutdown &  no shutdown , but also not working. as in attached file
also Checked command "show power inline " and check the used/remaining power , it was 80/750
please help
23 Replies 23
I'm still facing the same problem , can you please advice
Reboot the switch.
If the issue persist, post the complete output to the command "sh post".
I attached the required command
Hello
most probably the switch poe is on it way out - it does happen
do the fauly ports work as normal access ports when POE is turned off?
Kind Regards
Paul
Yes, the fauly ports work as normal access ports when POE is turned off
What can I do ?
Hello
sounds like the Poe is faulty it does happen I would suggest you RMA it as Leo stated
Kind Regards
Paul
@eng_adel273 wrote:
15.0(2a)EX5
Hold on.  I am NOT troubleshooting anything that runs on "EX" image.
Upgrade to something more recent than a "re-build" like that.
can you please send a clear steps
Kindly read the Release Notes.  There is a section which provides detailed steps about how to upgrade the IOS of a stack of switches.
