Point to Multi-Point WAN Solutions
mitchell.smith
Hi, I need to connect a HQ office to 3 branch offices over point-to-point T1's.
I know I can use frame relay for this but what other way will work? Is it possible to have 3 routers talking to 1 router with 3 WIC-1DSU-T1 cards, each with its own P2P T1? Any ideas are appreciated! Thanks, Mitchell
harish.ab
Hi Mitchell,
If you are using seperate interfaces, u need to have 3 seperate lines too. why dont you think about some MPLS solution if your service provoder supports. Then you can acheive full meshed connectivity
Harish
Joseph W. Doherty
"Is it possible to have 3 routers talking to 1 router with 3 WIC-1DSU-T1 cards, each with its own P2P T1?"
Believe the answer is yes.
Besides Harish's suggestion of MPLS, and yours of frame-relay, both ATM or Internet VPN is also possible.
