Point to Point Question
winslowtravis
I would like to combine two point to point connections over 2 routers.
I believe it is called aggregation. Basically combining two point to point connections so that we can double our speed.
I will be running a 7206 to a 2610.
What are the ios commands associated with setting this up. And does anyone have a sample config possibly? Thank you for your time.
5 Replies 5
gschertz
So if I understand this right. You will have 2 PTP t1's between the locations? I personaly do not have any experiance bonding two circuits together, but you can load balance across the two
topo
router 1 --------first link ----------- router 2
\ ------ second link----------/
so if first link is network 1.1.1.1\30
and second link is network 1.1.1.5\30
lan 1 is 1.0.0.1\24 lan 2 is 1.0.2.1\24
at each end using static routing
router 1
ip route 1.0.2.0 255.255.255.0 1.1.1.2
ip route 1.0.2.0 255.255.255.0 1.1.1.6
router 2
ip route 1.0.1.0 255.255.255.0 1.1.1.1
ip route 1.0.1.0 255.255.255.0 1.1.1.5
now you will load balance across the two links.
But hopefully someone will let us know how to bond them together. I know the local telco here will not unless the t1 circuits are ATM and then using IMA they can appear and be used as one circuit.
GENE
A good option is to use Multilink PPP. An example follows. You will then get a single interface (the multilink interface) that is like an aggregate interface on which you can configure your layer 3 parameters.
Router 1
interface Multilink1
ip address 10.1.1.1 255.255.255.0
no cdp enable
ppp multilink
ppp multilink group 1
interface Serial0
no ip address
encapsulation ppp
ppp multilink
interface Serial1
no ip address
encapsulation ppp
ppp multilink
Hope that helps - pls rate the post if it does.
Paresh
Thanks for your reply Gene. I was thinking of taking the load balancing option. But I have heard that we can actually bond the circuits as you referred to. These are not ATM circuits.
I should add that the multilink interface will have an effective bandwidth that is the sum of the bandwidths of the two 'bonded' interfaces ...
Paresh.
Thanks Paresh. I will give it a go. I will be sure to rate after I test and implement it.
Thanks again.
