policy base routing and IP SLA tracking to load-sharing
What I would like to achieve is policy base routing and IP SLA tracking to load-sharing default route with fail-over
Could you please help ?
my config :
track 1 ip sla 1 reachability
delay down 3 up 3
track 2 ip sla 2 reachability
delay down 3 up 3
track 3 ip sla 3 reachability
delay down 3 up 3
interface Port-channel1
no ip address
hold-queue 150 in
interface Port-channel1.10
encapsulation dot1Q 10
ip address 172.16.10.1 255.255.255.248
ip nat inside
ip virtual-reassembly in
ip policy route-map MM
interface Port-channel1.20
encapsulation dot1Q 20
ip address 172.16.20.1 255.255.255.248
ip nat inside
interface Port-channel1.230
description ISP1-internet
encapsulation dot1Q 230
ip address 1.1.1.1 255.255.255.248
ip nat outside
interface Port-channel1.231
description ISP2-nointernet
encapsulation dot1Q 231
ip address 2.2.2.1 255.255.255.248
ip nat outside
interface GigabitEthernet0/0
description EtherChannel To Lan
no ip address
duplex auto
speed auto
channel-group 1
no mop enabled
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
channel-group 1
interface FastEthernet0/2/1
description link2-nointernet
bandwidth 100000
ip address 11.11.11.1 255.255.255.248 secondary
ip address 172.16.201.1 255.255.255.248
ip nat outside
duplex auto
speed auto
interface FastEthernet0/3/0
description link1-internet
bandwidth 100000
ip address 12.12.12.1 255.255.255.224 secondary
ip address 172.16.200.1 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no ip route-cache
duplex auto
speed auto
router ospf 100
router-id 5.5.5.5
log-adjacency-changes detail
network 11.11.11.0 0.0.0.7 area 0
network 12.12.12.0 0.0.0.31 area 0
ip nat pool Link2 12.12.12.6 12.12.12.6 prefix-length 28
ip nat pool Link1 12.12.12.5 12.12.12.5 prefix-length 27
ip nat pool ISP2-noint 2.2.2.5 2.2.2.5 prefix-length 29
ip nat pool ISP1-int 1.1.1.5 1.1.1.5 prefix-length 29
ip nat inside source route-map ISP1 pool ISP1-int overload
ip nat inside source route-map L1 pool Link1 overload
ip nat inside source route-map L2 pool Link2 overload
ip nat inside source route-map ISP2 pool ISP2-noint overload
ip route 0.0.0.0 0.0.0.0 172.16.200.2 225 track 1
ip route 0.0.0.0 0.0.0.0 1.1.1.2 225 track 2
ip route 0.0.0.0 0.0.0.0 172.16.201.2 225 track 3
ip sla 1
icmp-echo 172.16.200.2 source-ip 172.16.200.1
frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 1.1.1.2 source-ip 1.1.1.1
frequency 5
ip sla schedule 2 life forever start-time now
ip sla 3
icmp-echo 172.16.201.2 source-ip 172.16.201.1
frequency 5
ip sla schedule 3 life forever start-time now
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 192.168.20.0 0.0.0.255
access-list 2 permit 192.168.20.90
access-list 2 permit 192.168.20.121
access-list 14 permit 192.168.10.32
access-list 14 permit 192.168.10.56
access-list 15 permit 192.168.20.69
access-list 15 permit 192.168.20.223
route-map MM permit 10
match ip address 15
set ip next-hop 2.2.2.2
route-map MM permit 11
match ip address 14
set ip next-hop 1.1.1.2
route-map ISP2 permit 20
match ip address 1
match interface Port-channel1.231
route-map L2 permit 10
match ip address 1
match interface FastEthernet0/2/1
set ip next-hop 172.16.201.2
route-map L1 permit 10
match ip address 1
match interface FastEthernet0/3/0
set ip next-hop 172.16.200.2
route-map RM-NAT permit 5
match ip address 2
route-map ISP1 permit 20
match ip address 1
match interface Port-channel1.230
route-map Loadsharing permit 10
match ip address 1
set ip next-hop verify-availability 172.16.201.2 10 track 3
set ip next-hop verify-availability 172.16.200.2 11 track 1
set ip next-hop verify-availability 1.1.1.2 12 track 2
show ip route
O*E1 0.0.0.0/0 [110/221] via 172.16.201.2, 1d16h, FastEthernet0/2/1
[110/221] via 172.16.200.2, 1d16h, FastEthernet0/3/0
I see a problem with this because this device is doing the NAT. What you are talking about could load balance things between ISP's in the middle of a connection. That would cause the client to get its public address changed which would break the connection. This is theoretically possible IF the client maintains a consistent NAT address AND both ISP's accept the addresses to which the clients are NAT'd. Otherwise I can't see how you would accomplish this.
