Policy Based route
John Levy
Hello , i have the next topology  -
I tried to practice on PBR , when R1 ping R3 Loopback address it will match the Policy based routing.
I did the following configuration on R1 but don't see any match:
access-list 101 permit ip any host 200.200.200.1
route-map PBR permit 10
match ip address 101
set ip next-hop 1.1.1.2
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.0
ip policy route-map PBR
But on the show route-map / debug ip policy i can not see any output.
R1#show route-map
route-map PBR, permit, sequence 10
  Match clauses:
    ip address (access-lists): 101
  Set clauses:
    ip next-hop 1.1.1.2
  Policy routing matches: 0 packets, 0 bytes
R1#show ip route
Gateway of last resort is not set
D    200.200.200.0/24 [90/435200] via 1.1.1.2, 00:17:07, FastEthernet0/0
    1.0.0.0/24 is subnetted, 1 subnets
C      1.1.1.0 is directly connected, FastEthernet0/0
    2.0.0.0/24 is subnetted, 1 subnets
D      2.2.2.0 [90/307200] via 1.1.1.2, 00:18:02, FastEthernet0/0
Any ideas ?
cassiolange
Hello John,
When router generate the packets, you need use ip local policy route-map
https://www.cisco.com/c/en/us/td/docs/ios/12_2/qos/configuration/guide/fqos_c/qcfpbr.html
http://blog.ine.com/2008/02/13/tricks-with-local-policy-routing/
Jon Marshall
As a side note, if you want to practice PBR it is better to have multiple paths to the same destination IP address.
Your topology only have one path so using PBR is not really relevant.
Jon
I agree with the point made by Jon. I will also point out that the routing table posted indicates that the routers are running EIGRP and the destination would be reached using normal routing in exactly the same way that PBR would use. So it would be very difficult to determine whether PBR was working as desired or not. Remember that the point of PBR is to send traffic some way that is different from what normal routing would do.
Rick
Rick
