Policy based routing and exact route
iores
Level 3
Level 3
can command show ip cef exact-route be used when PBR is configured? In other words, will command output take into consideration PBR and show correct outgoing interface and next-hop?
I will check
NOTE:- I reply to your STP redundancy Link please closed that post.
MHM
it good Q
I run lab and point the traffic to 23.23.23.23 toward R3 but there is static route toward R2
the show ip cef exact-route show what we see in RIB and not consider the PBR
since PBR is run in CPU so I think it override the CEF table
MHM
MHM makes a good point. PBR provides an alternative for forwarding traffic that is different from the logic found in the routing table.  show ip cef exact-route gets its information from the routing table and so we would not expect it to reflect the PBR logic.
Rick
