Policy Based Routing Help.
jfitz0715
Getting error when attempting to run command..."Device(config)# route-map pbr-map permit"  Getting "Invalid Input detected at '^' marker
I can run this command on my Cisco Catalyst 3850-XS 10g SPF Switch but not my Cisco Catalyst 2960-X.
Looking for so insight on this issue.
Thanks.
~ Jerry
adrian.porreca
Level 4
Level 4
it's possible you need to change the sdm template that the switch is using. Try "sdm prefer routing" on global configuration mode
regards
anatols
Catalyst 2960-x has 3 feature sets -
IP Lite
(Layer 3)
LAN Base
(Layer 2)
LAN Lite
(Basic Layer 2)
What is feature set on you catalyst ?
Consolidated Platform Configuration Guide, Cisco IOS XE 15.2(6)E (Catalyst 2960-X Switch) - Policy-Based Routing (PBR) […
Cisco Catalyst 2960-X Series FAQ - Cisco
