Policy based routing is not working ....
aslam.bajwa
Level 3
Level 3
i have applied PBR on mY customer router but its not working but with the same configuration its working on GNS3.
on my cutomer router GETVPN is also  configured it can make any issue with PBR.
plz advise
Vivek Ganapathi
Level 4
Level 4
Aslam,
You may need to provide more information like topology diagram, configurations etc. This help us to help you better.
Vivek
Always make sure you apply the route-map to an interface.
Thanks for your replies :
yes , i have applied the route-map on an interface as i mentioned befor thta same configuration is in GNS3 lab . below is the interface configuration which is showing that route-map is NOT applied on this interface because i had taken that configuration before configuring PBR. but as of now route-map has been applied on the same interface . please advice.
interface FastEthernet0/0
  ip address 10.20.17.100 255.255.255.0
ip access-group filter in
ip access-group filter-out out
ip ospf network point-to-multipoint non-broadcast
load-interval 30
duplex auto
speed auto
crypto map GETVPN_MAP
post your gns3 file with configs and post the running config for real device.
Regards.
Alain
