Policy Based Routing missed packets
tamimkushjar
Hi Guys,
This is my first post and I hope it's posted in the right directory.
I have a problem with Policy Based Routing on my router.
It's a configuration which is working for a very long time.
Recently I have add some additional rules to make use of the policy based routing.
This seems to work since I see the ACL counters increase, however I also have noticed that not all packets are being picked!
Which just goes over de standard WAN interface!
                                            WAN ----------MPLS-------------
PBR LAN port Remote router<
                                            PBR out---------ISP TUNNEL------
################PBR configuration##############
interface FastEthernet0/0
description LAN interface
ip address 172.26.32.1 255.255.240.0
ip access-group VPNLANin in
no ip proxy-arp
ip policy route-map traffic-offload
route-map traffic-offload permit 20
description Offloadingv2-via-Nijmegen
match ip address traffic-offload-acl
set ip next-hop recursive 172.25.100.209
Extended IP access list traffic-offload-acl
283 permit tcp any gt 0 host 172.25.16.11 gt 0 (251864 matches)  <==Notice the matches are increasing for PBR
285 permit ip any host 172.25.16.11 (817 matches)
#############WAN Interface test####################
interface Serial0/0/0:0
description WAN INTERFACE
bandwidth 1024
ip address x.x.x.x 255.255.255.252
ip access-group VPNWANin in
ip access-group TEST out
ip flow ingress
ip flow egress
Extended IP access list TEST
    10 permit tcp any gt 0 host 172.25.16.11 gt 0 log (59807 matches)  <==Still packets which don't seem to be matched in the ACL above!
    20 permit ip any any (414136 matches)
Prove of packets being sent towards de default WAN link
Jul  5 12:06:17 UTC: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 265 packets
Jul  5 12:06:20 UTC: %SEC-6-IPACCESSLOGP: list TEST permitted tcp 172.26.32.19(52860) -> 172.25.16.11(111), 1 packet
Jul  5 12:06:22 UTC: %SEC-6-IPACCESSLOGP: list TEST permitted tcp 172.26.32.200(443) -> 172.25.16.11(52431), 1 packet
Jul  5 12:06:24 UTC: %SEC-6-IPACCESSLOGP: list TEST permitted tcp 172.26.32.19(52096) -> 172.25.16.11(6504), 1 packet
Jul  5 12:06:26 UTC: %SEC-6-IPACCESSLOGP: list TEST permitted tcp 172.26.32.19(52882) -> 172.25.16.11(111), 1 packet
Jul  5 12:06:28 UTC: %SEC-6-IPACCESSLOGP: list TEST permitted tcp 172.26.32.19(52900) -> 172.25.16.11(111), 1 packet
Jul  5 12:06:47 UTC: %SEC-6-IPACCESSLOGP: list TEST permitted tcp 172.26.32.19(52953) -> 172.25.16.11(60217), 1 packet
Jul  5 12:06:49 UTC: %SEC-6-IPACCESSLOGP: list TEST permitted tcp 172.26.32.10(6050) -> 172.25.16.11(52445), 1 packet
Jul  5 12:06:50 UTC: %SEC-6-IPACCESSLOGP: list TEST permitted tcp 172.26.32.10(62031) -> 172.25.16.11(6504), 1 packet
Jul  5 12:06:51 UTC: %SEC-6-IPACCESSLOGP: list TEST permitted tcp 172.26.32.19(53029) -> 172.25.16.11(111), 1 packet
Jul  5 12:06:53 UTC: %SEC-6-IPACCESSLOGP: list TEST permitted tcp 172.26.32.200(443) -> 172.25.16.11(52431), 1 packet
Jul  5 12:06:56 UTC: %SEC-6-IPACCESSLOGP: list TEST permitted tcp 172.26.32.19(59866) -> 172.25.16.11(6502), 1 packet
Jul  5 12:06:57 UTC: %SEC-6-IPACCESSLOGP: list TEST permitted tcp 172.26.32.19(53055) -> 172.25.16.11(111), 1 packet
Jul  5 12:07:00 UTC: %SEC-6-IPACCESSLOGP: list TEST permitted tcp 172.26.35.200(2463) -> 172.25.16.11(52518), 1 packet
Personally I am think maybe some buffer is overloaded however I don't see any counters increased!
Also de CPU is at a acceptable level!
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is 0022.559b.de42 (bia 0022.559b.de42)
  Description: LAN interface
  Internet address is 172.26.32.1/20
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 01:16:50
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 363000 bits/sec, 171 packets/sec
  30 second output rate 410000 bits/sec, 155 packets/sec
     635605 packets input, 219515361 bytes
     Received 20422 broadcasts, 0 runts, 0 giants, 0 throttles
     214 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     573762 packets output, 299583341 bytes, 0 underruns
     0 lost carrier, 0 no carrier
li01-lgqy# sh route-map traffic-offload
route-map traffic-offload, permit, sequence 20
  Match clauses:
    ip address (access-lists): traffic-offload-acl
  Set clauses:
  Policy routing matches: 350236 packets, 139030057 bytes
route-map traffic-offload, permit, sequence 30
  Match clauses:
  Set clauses:
    ip next-hop recursive 172.25.100.217
  Policy routing matches: 0 packets, 0 bytes
li01-lgqy   12:10:42 PM Friday Jul 5 2013 UTC
    8222222132111111111222255222211111    11111322328422221 1   1  1 1122222
    697785175598767979973850844309803289895213514413404351884987288593920584
100
90 *
80 *                                               *
70 *                                               *
60 *                       *                       *
50 *                      **                       *
40 *       *              **                       **
30 ******  **         * ****                  *  * **  *                **
20 *******************************       *   *************        *  ******
10 ######***********#############*************###########*************#####
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
                  * = maximum CPU%   # = average CPU%
So as you can see I don't see any abnormalities maybe someone have any suggestions or ideas?
tamimkushjar
The problem is solved! The reason was that the recursive route was not stable!
With implementation of proper route-maps to block the recursive routes.
Which was being resent back over the the MPLS cloud.
