Policy based routing not working
jasonww04
One router with two different ISPs. I want 3 subnets to go out one ISP and 1 subnet to go out the other. What's wrong with my config?
interface FastEthernet0/0
ip address 172.17.35.1 255.255.255.0 secondary
ip address 172.18.35.1 255.255.255.0
ip nat inside
ip policy route-map Director
interface FastEthernet0/0.1
encapsulation dot1Q 2
ip address 172.19.35.1 255.255.255.0
ip access-group BlockLANAllowPrint in
ip nat inside
interface FastEthernet0/0.2
encapsulation dot1Q 3
ip address 172.20.35.1 255.255.255.0
ip nat inside
interface FastEthernet0/1
  ip address 206.x.x.4 255.255.255.248
ip nat outside
crypto map to_vpn
interface FastEthernet0/1/0
switchport access vlan 10
interface Vlan10
ip address 173.x.x.3 255.255.255.252
ip nat outside
ip route 0.0.0.0 0.0.0.0 206.x.x.3 9
ip route 0.0.0.0 0.0.0.0 173.x.x.4 25
ip nat inside source route-map NAT interface FastEthernet0/1 overload
ip nat inside source route-map Residents interface Vlan10 overload
ip access-list extended BlockLANAllowPrint
deny   ip 172.20.35.0 0.0.0.255 172.19.35.0 0.0.0.255
deny   ip 172.20.35.0 0.0.0.255 172.18.35.0 0.0.0.255
deny   ip 172.20.35.0 0.0.0.255 172.17.35.0 0.0.0.255
permit tcp 172.19.35.0 0.0.0.255 172.18.35.0 0.0.0.255 eq 9100
permit tcp 172.19.35.0 0.0.0.255 172.18.35.0 0.0.0.255 eq lpd
permit tcp 172.19.35.0 0.0.0.255 172.18.35.0 0.0.0.255 eq 161
deny   ip 172.19.35.0 0.0.0.255 172.18.35.0 0.0.0.255
deny   ip 172.19.35.0 0.0.0.255 172.17.35.0 0.0.0.255
permit ip 172.19.35.0 0.0.0.255 any
permit ip 172.20.35.0 0.0.0.255 any
ip access-list extended NAT
deny   ip any 10.0.0.0 0.0.0.255
deny   ip any 10.11.0.0 0.0.255.255
deny   ip 172.18.35.0 0.0.0.255 172.18.136.0 0.0.0.255
deny   ip any 10.18.0.0 0.0.0.255
deny   ip 172.18.35.0 0.0.0.255 10.41.0.0 0.0.255.255
deny   ip 172.18.35.0 0.0.0.255 10.52.0.0 0.0.255.255
deny   ip 172.18.35.0 0.0.0.255 10.253.1.0 0.0.0.255
deny   ip 172.18.35.0 0.0.0.255 10.254.1.0 0.0.0.255
deny   ip any 10.61.0.0 0.0.255.255
deny   ip 172.18.35.0 0.0.0.255 172.18.34.0 0.0.0.255
deny   ip 172.18.35.0 0.0.0.255 172.18.22.0 0.0.0.255
permit ip 172.18.35.0 0.0.0.255 any
permit ip 172.17.35.0 0.0.0.255 any
ip access-list extended Residents-ACL
ip access-list extended TWFiber-ACL
route-map Director permit 10
match ip address Residents-ACL
set ip next-hop 173.x.x.4
route-map Director permit 11
match ip address TWFiber-ACL
set ip next-hop 206.x.x.3
route-map Residents permit 10
match interface Vlan10
route-map NAT permit 10
match ip address NAT
match interface FastEthernet0/1
Marwan ALshawi
you have overlaping between the PBR policies and NAT policies
try to make it like this but review it in terms of the requried ACLs
also have a look at the bellow docuemnt  i posted on CSC before for understanding and improvments to your setup
https://supportforums.cisco.com/docs/DOC-8313
good luck
if helpful Rate
9 Replies 9
p.mcgowan
Level 3
Level 3
looks like you are doing NAT on the interfaces you are trying to PBR but the NAT address range is not being matched on the route-maps
Marwan ALshawi
good luck
if helpful Rate
Still doesn't work. 172.20.35.0/24 network cannot get to the internet while the other three subnets have no problems.
can you try this
update only the NAT route-maps as bellow
access-list 10 permit any
match ip address 10
match ip address 10
then after you updated cleart the the nat sessions then try it again
good luck
Putting the match ip address 10 under route-map NAT crashed the router, even when I first removed the ip nat statement using the route-map. I'm at a total loss as to how this isn't working.
I even tried a simpler config and it fails as well
ip nat inside
ip nat inside
ip nat inside
set ip next-hop 173.167.242.134
Looks like you have a wrong entry in the ACL NAT.
With the initial configuration you have posted here, remove this entry from the ACL NAT & remove "set ip next-hop" from the route-maps "Residents" & "NAT".
the permit any any acl 10 suggested about should do it not sure why did not work as this ACL will be for NATing after the PBR kicked in !! ( at least for testing )
Finally got the router on a SmartNet contract. Hopefully, the issue is figured out tomorrow. I'll post results.
Here is the config that is working - turns out I was testing it wrong. Sourcing the trace from f0/0.2 was failing because traffic generated by the router itself will not be routed by PBR.
ip nat inside
ip route 0.0.0.0 0.0.0.0 206.169.3.33 9
