Policy based routing on C4510 possible ?
routeinet
Currently, I'm using cat4000-i9s-mz.122-25.EWA7.bin image on C4510.
Is C4510 capable of running Policy based routing ? If it's possible, Are there memory requirement to run PBR on C4510
hoogen_82
Level 4
Level 4
http://tools.cisco.com/ITDIT/CFN/Dispatch?act=featdesc&task=display&featureId=233
http://tools.cisco.com/ITDIT/CFN/Dispatch?HMR_DDM=0&HIM_Id=767885&HDDMPlatFamDet=202&HDDMFeatSetDet=1166&HPN_Text=&Q1Submit=CONTINUE&act=rlsSelect&task=display
The feature that you ask is supported in your IOS. THough there are no memory requirements to run PBR, after the implementation check the show proc cpu and show proc mem to see affect on the chassis.
Hoogen
Do rate if this post helps:)
Amit Singh
You are running Standard Image on the switch and I am in doubt if PBR is supported in that. To run PBR you need an enhanced image i.e Cat4000-i5k9s-mz.122-25.EWA.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/ol_5184.htm
HTH,Please rate if it does.
-amit singh
