Policy-Based Routing problem
Hi all,
I have configured Policy-Based Routing on Cisco 3825 ( C3825-ADVENTERPRISEK9-M, Version 15.1(4)M5 ), but it isn't working as expected.
This is config:
route-map PBR_ROUTE permit 10
match ip address PBR_LIST
set interface Tunnel1
route-map PBR_ROUTE permit 20
set interface Tunnel2
route-map PBR_ROUTE permit 30
set interface Tunnel3
route-map PBR_ROUTE permit 40
set interface Tunnel4
When interface Tunnel1 is up all ok, but when I shutdown interface Tunnel1, traffic doesn't go through interface Tunnel2.
"show route-map" shows matching only for sequence 10 even when interface Tunnel1 is down:
route-map PBR_ROUTE, permit, sequence 10
  Match clauses:
    ip address (access-lists): PBR_LIST
  Set clauses:
    interface Tunnel1
  Policy routing matches: 716 packets, 104664 bytes
route-map PBR_ROUTE, permit, sequence 20
  Match clauses:
  Set clauses:
    interface Tunnel2
  Policy routing matches: 0 packets, 0 bytes
route-map PBR_ROUTE, permit, sequence 30
  Match clauses:
  Set clauses:
    interface Tunnel3
route-map PBR_ROUTE, permit, sequence 40
  Match clauses:
  Set clauses:
    interface Tunnel4
I also tried this PBR with IP SLA but result is the same.
So what is wrong and what to do?
Harold Ritter
Hi Haratyun,
This is normal behavior as the match statement in instance 10 keeps matching the incoming traffic even if tu1 goes down. If you want traffic to be forwarded to tu2 when tun1 is down, you need to add tu2 on the "set interface" statement under instance 10 as follow:
set interface Tunnel1 Tunnel2
Harold Ritter
Hi Haratyun,
