Policy-map and routing problem with an internal https server
habbas.ali
i have a little problem,
i have an internet router with three interfaces. An ethernet, a serial, and an adsl.
Because my provider don't give public fixed ip address with adsl but only with leased line
I ve created a policy map to send and receive all smtp traffic by the serial (public ip address to my mail server)and any others traffic by the adsl.
Everything works fine.
But now i need to grant access to an internal https server from Internet.
So i create a static nat for the https server, and grant access in my firewall.
When i connect to the https server (the connection is from internet to the serial wich have the fixed public address), i don't receive the response, i can see the connection in https server. So the back packets are losed.(may be they are sending to the adsl interface cause the policymap)
The interesting thing is: if i am connecting with a known internet address, and i create a route in the router to send all traffic with this address to the serial interface it works fine!!
So my problem is when an internet client open a https session to the server how can i configure the router to route packets from the internal server to internet by the serial and not the adsl.
Thanks for any help
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service sequence-numbers
hostname Internet_router
enable secret # ######################
enable password ######################
ip subnet-zero
ip tcp synwait-time 10
no ip bootp server
fax interface-type fax-mail
mta receive maximum-recipients 0
interface ATM0/0
bandwidth 1544
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
no fair-queue
interface FastEthernet0/0
ip address aaa.aaa.aaa.aaa (private adress)
duplex auto
speed auto
no cdp enable
shutdown
interface Serial0/0
ip address bbb.bbb.bbb.bbb (fixed public address)
ip access-group 102 in
encapsulation ppp
no cdp enable
interface FastEthernet0/1
ip address ccc.ccc.ccc.ccc (fixed public address)
ip nat inside
ip policy route-map route-smtp
speed auto
full-duplex
no cdp enable
interface Dialer1
bandwidth 1544
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname ###########
ppp chap password ######################
ppp pap sent-username ######## password ###################
ip nat inside source list 103 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Serial0/0 50
ip route ############################################
ip route w.x.y.z 255.255.255.0 inteface S0 here is the route i ve created for a web client with the public address w.x.y.z
no ip http server
ip pim bidir-enable
logging facility local2
logging ######################
access-list 102 deny tcp any any eq telnet
access-list 102 permit tcp any any
access-list 102 permit ip any any
access-list 103 permit ip host ############### any
access-list 104 permit tcp host ############## any eq smtp
dialer-list 1 protocol ip permit
no cdp run
route-map route-smtp permit 10
match ip address 104
set interface Serial0/0
set ip next-hop ###################
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password ?#?############
login
end
2 Accepted Solutions
Try removing the set interface command from the route-map and leave the set ip next-hop by itself along with the match 104.
You can also try turning debug on 104 ACL and see why the HTTPS traffic is not working.
On the route-map you are only matching for HTTPS traffic while in the ip route, all traffic is valid. Perhaps the server is using other protocols to negociate this connection. As a test, include all ports in the 104 ACL and try again.
I believe above access list should be corrected to:
access-list 104 permit tcp host ############## eq https any
Because your server sends packets from https port, but not to https.
7 Replies 7
Edison Ortiz
You need to include the https server in the 104 ACL
Something like:
access-list 104 permit tcp host ############## any eq https
Hello
No did not work with this access-list.
The problem is when i enter an ip route for the client internet address to the serial it work.
For exemple, i am connecting to internet by adsl, if i try to connect to the internal https server it don't work but if in the office router i enter an ip route my adress interface s0.0 it work
Any ideas
I am not sure why matching this traffic on acl 104 would not work. When you add the https to acl 104, and issue a "sh access-lists 104", do you see the counter increase for the line pertaining to https traffic?
CSCO10408957
PIX:
access-list acl_123 extended permit ip host HTTPServer any
static (inside,outside) Real-IP access-list acl_123
It make the STATIC with traffic requirement.
there is already a static for the https server because it is also a proxy server.
static (inside,outside) real-ip private-ip
do i have to add the static with access-list???
