05-20-2013 07:56 AM - edited 03-04-2019 07:57 PM
I have a VPN between my home and office via a HughesNet G4 Internet connection. My most important connection is the VoIP phone. Right now I haee my phone using G729r8 codec and my download RTP stream is perfect! However, my upload RTP stream ends up with paclets being stacked up. If I use G711u coded, my upload packets stack up so bad that the person I am calling cannot even hear me.
I asked for help int the VoIP section of this forum and they suggested that I create a policy-map nad a class-map to priortize my RTP trafffic but no one seems to know how I should write thies mappings or on which interface to apply them.
Below is a diagram of my network and VPN connection. I have a GRE Tunnel that connects me to my office network. I want the RTP traffic to get top priority and the maximum bandwadth of my Internet connection. I do have access to hte cli on my work routers should I need to do any data shaping on that end too. I can provide any config files that you may need.
I am still new to this stuff and willing to learn. But since this is my office phone and I need to contact customers, I need a very quck solution; otherwise, I would do the research and figure this out myself. I am very thankful for any help that you may be able to provide.
My IP phone is on the 192.168.3.0 network and the office CME VoIP router is on the 192.168.2.0 netowrk. The GRE Tunnel is on the 172.30.1.0 netowrk. My office edge router has a public static IP and my edge router has a dynamic public IP.
---Michael
05-20-2013 01:07 PM
Hi Michael.
I dont think you applied my class-maps correctly.
Can you show me a running config from the router excluding any public addresses and username/paswods?
Simon
05-20-2013 01:53 PM
Its attached t the first post above, Home CME router.txt.zip (2.7 K)
05-20-2013 02:41 PM
Thanks Micheal, As mentioned previously, I think you have configured the class-maps wrong, it looks like you have configured the following;
class-map VOICE
match dscp ef
match dscp AF21
class-map class-default
Can you change to;
class-map VOICE
match dscp ef
(leave out the AF21 section), I was looked at your COS-DSCP mapping on the switch and everything not EF should be classified as COS 0 by default.
Also can you change the tunnel mtu;
int tun0
ip mtu 1476
exit
Then send me a show policy-map int tun0
Simon
05-20-2013 03:02 PM
Hello
(matches all voip payload)
access-list 100 permit udp any any range 16384 32767
access-list 100 permit tcp any any eq 1720
class-map match-all Qos-VOIP_child
match access-group 100
policy-map Qos-VOIP_child
class Qos-VOIP
priority xx
class class-default
fair queue
policy-map Qos-VOIP_parent
class class-default
shape average xxx (if applicable)
service-policy output Qos-VOIP_child
You can apply a service policy to either the tunnel interface or to the underlying physical interface. The decision of where to apply the policy depends on the QoS objectives. It also depends on which header you need to use for classification.
Apply the policy to the tunnel interface without qos-preclassify when you want to classify packets based on the pre-tunnel header.
Apply the policy to the physical interface without qos-preclassify when you want to classify packets based on the post-tunnel header. In addition, apply the policy to the physical interface when you want to shape or police all traffic belonging to a tunnel, and the physical interface supports several tunnels.
Apply the policy to a physical interface and enable qos-preclassify on a tunnel interface when you want to classify packets based on the pre-tunnel header.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
05-20-2013 03:55 PM
Paul,
I was looking at your suggestion and I read that one somewhere. My question, Since I want VoIP RTP to have the higest priority of ANY traffic going out to the Internet, I think I should apply the policy to the physical interface. But I am unsure about the commands to use and which one of the two recommendataions I should do.
OR
Would you also please show me the commands for this part too? Do I use servce-policy out Qos-VOIP_parent? and apply it to my Gi0/0 interface?
Here is my current tunnel config:
interface Tunnel0
bandwidth 20000
ip address 172.30.1.2 255.255.255.252
ip mtu 1410
ip nhrp map multicast 55.9.6.90
ip nhrp map 172.30.1.1 55.9.6.90
ip nhrp network-id 1
ip nhrp holdtime 300
ip nhrp nhs 172.30.1.1
ip nhrp registration timeout 20
ip tcp adjust-mss 1360
qos pre-classify
tunnel source GigabitEthernet0/0
tunnel destination 55.9.6.90
tunnel key 1
tunnel protection ipsec profile WA-FLA
service-policy output GRE_TUNNEL_TRAFFIC_PARENT
05-21-2013 12:35 AM
Try applying the parent policy to the source interface of the tunnel- outbound ( gig0/0)
int tun0
qos pre-classify
int gig0/0
service-policy output Qos-VOIP_parent
res
Paul
Thanks.
05-20-2013 03:44 PM
Simon,
I removed the af21 but when I try to add class-map class-default I getthe following error:
% class-default is a well-known class and is not configurable under class-map
I see the PDriver made a different suggestion than yours. Should I add his to yours or replace yours with his? Have not done anything with PDriver's suggestions yet.
Tunnel0
Service-policy output: GRE_TUNNEL_TRAFFIC_PARENT
Class-map: class-default (match-any)
23650 packets, 2845062 bytes
5 minute offered rate 26000 bps, drop rate 0 bps
Match: any
Queueing
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 23465/4681286
shape (average) cir 100000000, bc 1000000, be 1000000
target shape rate 100000000
Service-policy : GRE_TUNNEL_TRAFFIC_CHILD
queue stats for all priority classes:
(pkts output/bytes output) 5811/1754922
Class-map: VOICE (match-all)
5811 packets, 1324908 bytes
5 minute offered rate 25000 bps, drop rate 0 bps
Match: dscp ef (46)
Priority: 50% (50000 kbps), burst bytes 1250000, b/w exceed drops: 0
17839 packets, 1520154 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
Queueing
(pkts output/bytes output) 17654/2926364
bandwidth 25% (25000 kbps)
I made a a 60 second phone call to a landline. The audio was as bad as when I was using G711ulaw. In other words, it got a lot worse.
When i put the mtu back down to 1410 it came back as was before but still not usable.
Suggestions?
05-20-2013 06:08 PM
The first two outputs are from the rotuers at the office side of the tunnel, The third output is from my home edge router. Rememver, I am connected to my office's CME router for my phone service. These outputs were taken after a 1 munite phone call over the tunner to a landline. The audio was very bad to the landline.
OFFICE CME ROUTER
GigabitEthernet0/0 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 001e.7a5d.8fa0 (bia 001e.7a5d.8fa0)
Internet address is 55.9.6.91/29
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full Duplex, 1Gbps, media type is T
output flow-control is XON, input flow-control is XON
Last input 00:00:06, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 15000 bits/sec, 15 packets/sec
5 minute output rate 15000 bits/sec, 14 packets/sec
1299977 packets input, 268699417 bytes, 1 no buffer
Received 70626 broadcasts (0 IP multicasts)
0 runts, 0 giants, 1 throttles
10 input errors, 0 CRC, 0 frame, 0 overrun, 10 ignored
0 watchdog, 0 multicast, 0 pause input
1292677 packets output, 256958568 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
33 lost carrier, 0 no carrier, 0 pause output
Service-Engine0/0 is up, line protocol is up
Hardware is I82559FE, address is 001e.7a5d.8fa2 (bia 001e.7a5d.8fa2)
Interface is unnumbered. Using address of GigabitEthernet0/1.2 (192.168.2.1)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Last input 00:00:02, output 00:00:00, output hang never
327885 packets input, 57548371 bytes, 0 no buffer
Received 145 broadcasts (0 IP multicasts)
770591 packets output, 112308153 bytes, 0 underruns
0 lost carrier, 0 no carrier
GigabitEthernet0/1 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 001e.7a5d.8fa1 (bia 001e.7a5d.8fa1)
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Full Duplex, 100Mbps, media type is T
Last input 00:00:00, output 00:00:00, output hang never
5 minute output rate 15000 bits/sec, 16 packets/sec
3762297 packets input, 453784983 bytes, 0 no buffer
Received 366698 broadcasts (264804 IP multicasts)
4463473 packets output, 499193175 bytes, 0 underruns
224 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/1.2 is up, line protocol is up
Internet address is 192.168.2.1/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 2.
GigabitEthernet0/1.10 is up, line protocol is up
Internet address is 192.168.10.5/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 10.
NVI0 is up, line protocol is up
Hardware is NVI
Interface is unnumbered. Using address of GigabitEthernet0/0 (55.9.6.91)
MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
Encapsulation UNKNOWN, loopback not set
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
OFFICE EDGE ROUTER
FastEthernet0/0 is up, line protocol is up
Hardware is Gt96k FE, address is 0019.e792.17ae (bia 0019.e792.17ae)
Internet address is 55.9.6.90/29
Full-duplex, 100Mb/s, 100BaseTX/FX
5 minute input rate 34000 bits/sec, 28 packets/sec
5 minute output rate 31000 bits/sec, 29 packets/sec
6056624 packets input, 900738211 bytes
Received 75191 broadcasts (0 IP multicasts)
0 watchdog
4840139 packets output, 1025607872 bytes, 0 underruns
0 output errors, 0 collisions, 7 interface resets
FastEthernet0/1 is up, line protocol is up
Hardware is Gt96k FE, address is 0019.e792.17af (bia 0019.e792.17af)
Internet address is 192.168.10.1/24
Last input 00:00:03, output 00:00:00, output hang never
5 minute input rate 28000 bits/sec, 29 packets/sec
5 minute output rate 29000 bits/sec, 28 packets/sec
4566399 packets input, 874388593 bytes
Received 340544 broadcasts (264783 IP multicasts)
1 input errors, 0 CRC, 0 frame, 0 overrun, 1 ignored
0 watchdog
5955439 packets output, 739508274 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
227 unknown protocol drops
Hardware is NVI
Interface is unnumbered. Using address of FastEthernet0/0 (55.9.6.90)
Tunnel0 is up, line protocol is up
Hardware is Tunnel
Internet address is 172.30.1.1/30
MTU 17912 bytes, BW 20000 Kbit/sec, DLY 50000 usec,
Encapsulation TUNNEL, loopback not set
Keepalive not set
Tunnel source 55.9.6.90 (FastEthernet0/0)
Tunnel Subblocks:
src-track:
Tunnel0 source tracking subblock associated with FastEthernet0/0
Set of tunnels with source FastEthernet0/0, 1 member (includes iterators), on interface
Tunnel protocol/transport multi-GRE/IP
Key 0x1, sequencing disabled
Checksumming of packets disabled
Tunnel TTL 255, Fast tunneling enabled
Tunnel transport MTU 1472 bytes
Tunnel transmit bandwidth 8000 (kbps)
Tunnel receive bandwidth 8000 (kbps)
Tunnel protection via IPSec (profile "FLA-WA")
Last input 00:00:00, output never, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 38
Output queue: 0/0 (size/max)
5 minute input rate 24000 bits/sec, 27 packets/sec
1441556 packets input, 108499847 bytes, 0 no buffer
1462878 packets output, 216434793 bytes, 0 underruns
CME HOME ROUTER
Hardware is MV96340 Ethernet, address is 0021.5527.1340 (bia 0021.5527.1340)
Description: Router - C3524 Port Fa0/23 192.168.70.1
Internet address is 110.7.8.138/29
Last input 00:00:04, output 00:00:00, output hang never
Queueing strategy: Class-based queueing
Output queue: 0/1000/0 (size/max total/drops)
5 minute input rate 180000 bits/sec, 59 packets/sec
5 minute output rate 46000 bits/sec, 48 packets/sec
64355787 packets input, 3006359974 bytes, 0 no buffer
Received 27017 broadcasts (0 IP multicasts)
4 input errors, 0 CRC, 4 frame, 0 overrun, 0 ignored
37841765 packets output, 3234187634 bytes, 0 underruns
68 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/0.69 is deleted, line protocol is down
Encapsulation ARPA
Hardware is MV96340 Ethernet, address is 0021.5527.1341 (bia 0021.5527.1341)
Description: Router - C3524 Port Fa0/20 Trunk
5 minute input rate 122000 bits/sec, 109 packets/sec
5 minute output rate 172000 bits/sec, 73 packets/sec
197513221 packets input, 59869928 bytes, 0 no buffer
Received 5112545 broadcasts (127399298 IP multicasts)
1 runts, 0 giants, 0 throttles
3 input errors, 1 CRC, 0 frame, 0 overrun, 1 ignored
94663333 packets output, 1976937090 bytes, 0 underruns
GigabitEthernet0/1.3 is up, line protocol is up
Internet address is 192.168.3.1/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 3.
GigabitEthernet0/1.30 is deleted, line protocol is down
Encapsulation ARPA
GigabitEthernet0/1.69 is up, line protocol is up
Internet address is 192.168.69.3/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 69.
GigabitEthernet0/1.100 is deleted, line protocol is down
Encapsulation ARPA
GigabitEthernet0/1.110 is up, line protocol is up
Internet address is 10.110.0.1/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 110.
GigabitEthernet0/1.115 is up, line protocol is up
Internet address is 10.115.0.1/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 115.
GigabitEthernet0/1.125 is deleted, line protocol is down
Encapsulation ARPA
Hardware is NVI
Interface is unnumbered. Using address of GigabitEthernet0/0 (110.7.8.138)
Hardware is Tunnel
Internet address is 172.30.1.2/30
MTU 17850 bytes, BW 20000 Kbit/sec, DLY 50000 usec,
Keepalive not set
Tunnel source 110.7.8.138 (GigabitEthernet0/0), destination 55.9.6.90
Tunnel Subblocks:
src-track:
Tunnel0 source tracking subblock associated with GigabitEthernet0/0
Set of tunnels with source GigabitEthernet0/0, 1 member (includes iterators), on interface
Tunnel protocol/transport GRE/IP
Tunnel transport MTU 1410 bytes
Tunnel protection via IPSec (profile "WA-FLA")
Last input 00:00:04, output 3w5d, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 40057
Queueing strategy: fifo (QOS pre-classification)
5 minute input rate 24000 bits/sec, 37 packets/sec
5 minute output rate 37000 bits/sec, 37 packets/sec
3311406 packets input, 245796282 bytes, 0 no buffer
Received 0 broadcasts (6 IP multicasts)
3328442 packets output, 488073528 bytes, 0 underruns
05-21-2013 04:39 AM
Hi Michael,
Okay we are now matching EF fine and I don't see any drops, can you clear interface counters then make a call. Then hang up and send me a show int tun0
QOS is looking good mate, you could increase the allowed priority of the interface % to 99 for a test if you wish!
policy-map GRE_TUNNEL_TRAFFIC_CHILD
Then try your call, if you still get bad call then the only thing left is to sort out the round trip time of 700ms, it needs to be below 150ms for one way (300ms in total)
Simon
05-21-2013 07:22 AM
I made the change above but I had to remove the class class-defualt bandwidth percent 25. Then I made a 1 minute call. Netxt I streamed some music and made another call for 1 minute. The music never quit playing. Results below.
After the results below, I set the class VOICE priority to 1 and the class class-default to 99 and the calls still had issues. I would think that the music would nearly quit if 99% of the bandwidth was going to the Voice packets????
Last clearing of "show interface" counters 00:03:05
5 minute input rate 150000 bits/sec, 47 packets/sec
5 minute output rate 34000 bits/sec, 35 packets/sec
9651 packets input, 3505828 bytes, 0 no buffer
8319 packets output, 1269296 bytes, 0 underruns
Encapsulation ARPA
5 minute input rate 115000 bits/sec, 93 packets/sec
5 minute output rate 151000 bits/sec, 56 packets/sec
19080 packets input, 2753556 bytes, 0 no buffer
Received 376 broadcasts (8575 IP multicasts)
11689 packets output, 3094919 bytes, 0 underruns
Encapsulation ARPA
Encapsulation ARPA
Encapsulation ARPA
Hardware is NVI
Hardware is Tunnel
Keepalive not set
Tunnel Subblocks:
src-track:
Last input 00:00:00, output 3w6d, output hang never
5 minute input rate 23000 bits/sec, 25 packets/sec
5 minute output rate 25000 bits/sec, 25 packets/sec
6903 packets input, 418348 bytes, 0 no buffer
6838 packets output, 1036616 bytes, 0 underruns
05-21-2013 07:31 AM
Thanks, from the above you have no queue drops which seems to signify that your QOS is now working as expected, However I guess your call was still bad, the next step is to find out how much delay and jitter you have while on a call.
When on a call can you press the ? button twice, this should give you all the statisctics, you are looking for as close to 0 jitter as possible and a MOS of 3.92 for G729.
Also as little latency as possible.
Also please share another show policy-map int tun0
We may now be at a stage where there is nothing more we can do, we have prioritised all your voice traffic as much as possible and if the overall latency of the link is too high then you might need to look into other connections.
Please change your MTU back to 1476, it should be 24 bytes smaller than the physical interface MTU to account for 24 bytes of GRE header.
Simon
05-21-2013 07:45 AM
Phone Stats:
Rec/Send Codec: G.729
Rec/Send Size:20ms
Rec Packets: 2768
Sebder Packets: 2771
Ave Jitter: 29
Max Jitter: 75
Recr Discarded: 1
Revr Lost Packets 1
MOS LQK: 3.7001
Aveg MOS LQK: 3.6970
Min MOS LQK: 3.5612
MAx MOS LQK: 3.7001
MOS LQK Version: 0.95
Cumulative Conceal Ration: 0.0013
Interval Conceal Ratio: 0.0000
Max Conceal Ratio:0.0328
Conceal Secs: 2
Serverly Conceal Secs:1
Network Protocol:
Tunnel0
13413 packets, 1175867 bytes
Match: any
Queueing
(pkts output/bytes output) 13415/2227258
(pkts output/bytes output) 12428/2063048
12428 packets, 1093664 bytes
Match: dscp ef (46)
Priority: 1% (1000 kbps), burst bytes 25000, b/w exceed drops: 0
985 packets, 82203 bytes
Match: any
Queueing
(pkts output/bytes output) 985/163878
bandwidth 99% (99000 kbps)
05-21-2013 07:56 AM
Thanks Michael,
Please change the percentages back around as you are only giving voice 1% max bandwidth at times of congestion and 99% to everything else.
Also, your jitter is quite high, but that could just be related to the delay across the link of 700ms.
Simon
05-21-2013 09:42 AM
Swtiched them back to :
class VOICE
priority percent 99
class class-default
bandwidth percent 1
Still crappy audio. One question, in Paul's config above he uses fair-queue, would that make any difference?
05-21-2013 09:54 AM
fair-queue in the class-default policy only applies to conversations. It applies express forwarding to the 'small talkers' compared to big talkers. However as this is only part of your class-default, it will not have any affect on the voice class.
At the moment, we are guaranteeing Voice traffic 99% of the available bandwidth should congestion occur.
The interface stats you gave me show that we are no longer dropping packets on the queues on the interfaces;
and the policy-map shows us also that the queues are no longer dropping traffic.
To be honest I think we've done everything we can do to prioritise VOIP traffic across the network.
Remember the primary reason for using QOS is a bandaid to assist with congestion and packet drops. If the bandwidth is too little or the delay is too much on a link then the only possible remediation task is to change the physical characteristics of the network (hence look into cable lines rather than wireless links).
Are you the host of the wireless link or is this provided by an ISP, have you spoken to the ISP to see if there is any issues with the link? Are you still getting +700msec response times from the head office?
Simon
