[policy map on POS interface (GSR)]
Carlos A. Silva
Level 3
Level 3
hi,
i tried applying the following configuracion on a POS interface in a GSR:
class-map match-any Internet_All
match access-group 21
access-list 21 permit any
policy-map Internet_Mark_In
class Internet_All
set ip dscp 0
but i got the follwing:
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#int pos1/1
Router(config-if)#servi input Internet_Mark_In
%Classmap 'Internet_All' not supported on interface POS1/1
Router(config-if)#
anybody know why this can happen?
please advice!
thanks in advance,
c.
htarra
Level 4
Level 4
If you do not have policing configured in the policy-map that is applied on the POS interface then the only counters you would see are for the default class as we can see it's the case from the outputs you attached. Also try this command sh int pos [/] | i (output queue)
