I need answers urgently please
justuniversity
Hello everybody,
I need answers for the following 2 questions regarding Router 7304 with 7304-NPE-G100 engin
1) what is the maximum CPU and memory utilization that is not recommended to be exceeded?
2) is it concidered as a blocking device, i.e. it is forwarding capacity is less that the summation of bandwidth of available interfaces?
Thank you
bvsnarayana03
Level 5
Level 5
1. Irrespective of the model, 75% of utilisation is considered to be alarming.
2. For answer to second point, pls refer this link. May be of some help
http://kb.pert.geant2.net/PERTKB/RouterHardwareLimits
Wilson Samuel
Level 7
Level 7
Ans. In any router, one must not exceed 65% - 75% CPU utilization and 80% of DRAM available, and this is the principle I apply to not only 7x00 routers but also to all routers in general.
Though technically NPE-G100 provides 1mpps of throughput however I shall be skeptical to say that it can Route-Switch even on its 3* 1Gps ports.
However having said that it can comfortable chew a fairly great amount of traffic through it when its expressed in Mpps
HTH,
Please rate all helpful threads
hello,
I would like to thank you for your interest in my issue. Kindly find the attached pdf document that shows routers models and "Fast/CEF Switching" for each of them. It is written for the 7304-NPE-G100 a value of 562 Mbps and 1 MPPS. I would like to make sure that is this is the same as forwarding capacity of the router?
Thank you again for your time
