policy-map question
billmatthews
I have Cisco 2900 routers running IOS 15.1.  I have a pair of routers with a serial interface into an MPLS network (T1)...
LAN1 - R1 - MPLSWAN - R2 - LAN2
Here is the existing QoS config:
interface Serial0/0/0
bandwidth 1536
max-reserved-bandwidth 100
service-policy input SERIAL-QOS-INBOUND
service-policy output SERIAL-QOS-OUTBOUND
policy-map SERIAL-QOS-OUTBOUND
class TAG-EF
  set dscp ef
  priority 480
class TAG-AF41
  set dscp af41
class TAG-AF42
  set dscp af42
  bandwidth remaining percent 10
class TAG-AF31
  set dscp af31
class TAG-AF21
  set dscp af21
  bandwidth remaining percent 25
class TAG-AF11
  set dscp af11
class class-default
  set dscp default
policy-map SERIAL-QOS-INBOUND
class TAG-EF
  set dscp ef
class TAG-AF41
  set dscp af41
class TAG-AF42
  set dscp af42
class TAG-AF31
  set dscp af31
class Video
  set dscp af21
  police cir 768000
   conform-action transmit
   exceed-action drop
class TAG-AF21
  set dscp af21
class TAG-AF11
  set dscp af11
class class-default
  set dscp default
We're having performance problems with video (af21).
Let's focus  on R2.  Am I reading this correctly that R2 will limit incoming video  (from R1) to 768k, and drop all traffic that exceeds that?  And then for  outbound video leaving R2, it will reserve it 25% of the bandwidth, but  beyond that it may experience drops?
Giuseppe Larosa
Hello Bill,
the policy map applied inbound implements a policer for class Video with CIR 768000 bps.
But there is also the following class-map that sets DSCP to AF21, is this wanted or it is just a typing error ?
The policy-map applied outbound should have a bandwitdth statement also for class TAG-AF41 as you are configuring a scheduler.
You have max-reserved-bandwidth 100%, the interface bandwidth set to 1536 kbps and a LLQ priority queue of 480 kbps.
when the link is full the class TAG-AF21 can get 25% of remaining bandwidth that is 25% of (1536-480 = 1056/4 = 264 kbps and this can be too little for video application
If the total usage of the link is less then 1536 the class TAG-AF21 can take some of the unused bandwidth and it can go over the 264 kbps. But if the link is fully used packets in excess of 264 kbps will be dropped and they will appear as output drops for the class in the output of
show policy-map interface ser0/0/0 output
Your understanding is correct
Hope to help
Giuseppe
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Yes (if it matches the class).
If the class has insufficient bandwidth, it will queue, and if the queue fills, it drops.
Bandwidth reservations only really agree with what you see in the config when 100% has been allocated and all classes want at least their defined bandwidth.
The bandwidth reservations are really better understood as setting bandwidth proportions, or bandwidth ratios, between classes.  For bandwidth sharing, you would get similar results for:
class 1
bandwidth percent 25
class 2
class 3
bandwidth percent 50
vs.
class 1
bandwidth percent 5
class 2
bandwidth percent 5
class 3
bandwidth percent 10
As in both case the ratios are 1:1:2
If just classes 1 and 2 wanted as much bandwidth as the interface would supply, each would obtain 50%.
If just classes 1 and 3 wanted as much bandwidth as the interface would supply, class 1 would get 33.3% and class 2 would get 66.7%.
Only if all three classes wanted full interface bandwidth would you see 25%, 25% and 50%.  (Which conforms to the 25,25,50 configuration, but doesn't appear to conform to the 5,5,10 configuration.)
In your case, class TAG-AF41 doesn't define a bandwidth allocation, so I'm unsure what "percentage" it thinks it has.
Show policy interface will provide stats, which should show if your video is getting drops in ingress or egress.
For MPLS WANs, as they often are configured to support multipoint, a common performance problem is congestion coming out of the cloud (which is "invisible" to router stats).
