Port 80 and Port 443 redirect...on Cisco 3925 Router
What I am trying to do is Redirect Port 80 and Port 443
Here is what I believe will work but I thought I would get some advice
ip nat inside source static tcp 192.168.0.3 80 interface GigabitEthernet0/2 60080
ip nat inside source static tcp 192.168.0.3 443 interface GigabitEthernet0/2 60443
Am I correct that this will work ??
Thanks for any Advice
sure it work
from OUTside you will connect using 60080 and router will NATing it to 192.168.0.3/80
it work.
go ahead
 Only with this config will not work. You need to identify your inside interface and outside interface and apply the command
ip nat inside and ip  nat outside respectively.
