port-channel on cisco ASR1001
Herman2018
Level 3
Level 3
hi, we have 2x ASR 1001 and created a bridge domain interface 20. Now we need to create port-channel between ASR and fortinet firewall. Can anyone pls help advise whether below config is correct? Thanks in advance.
interface BDI20
 description xxxxx
 ip address 10.x.x.1 255.255.255.248
int po50
desc xxxx
no ip address
2 Accepted Solutions
@Herman2018
 Seems to be right to me but you need to test with the Fortinet to be sure. Some devices does not support port-channel mode Active and you may need to adjust.  Another config is encapsulation dot1q. Both need to be tested, unless you already have a confirmation from the Fortinet on  this.
M02@rt37
Hello @Herman2018
Your configuration is well-structured for creating a port-channel between the ASR 1001 and the Fortinet firewall. Just ensure that you verify compatibility and configurations on both sides, and perform thorough testing once set up. If you have specific requirements or need to adjust settings based on your network design, feel free to share those for more tailored advice!
Note: Verify that LACP settings on the Fortinet firewall are compatible with your ASR configuration. Sometimes, different vendors may have unique defaults or requirements...
Best regards
9 Replies 9
@Herman2018
M02@rt37
Hello @Herman2018
Best regards
Bridge with forti? I dont get what you want here' and why you use PO?
What you need it make bridge between g0/0/1 and g0/0/2 if FW is in l2 mode.
This make traffic enter to FW inspect and then egress from other interface.
MHM
hi @MHM Cisco World & @paul driver ,
I never try before' but hope it work as you want
Goodluck
MHM
Hello @Herman2018
Just a note: ensure the MTU on both sides (ASR and Fortinet) matches. A mismatch in MTU can cause issues, particularly with services like LACP...
Best regards
hello
for what reason are you bringing - surley you would have l3 between the asrs and the fortinets?
Kind Regards
Paul
he need bridge to make HA work
instead of using SW he use bridge between two routers
but the codes he shared I dont think so it correct
but let him check and update us
MHM
hello
What are you bridging and why?
Kind Regards
Paul
