Multiple IPSec VTI between routers
peter.matuska1
Level 5
Level 5
I have 2 IOS-XE routers connected to internet with /30 subnet. I want to configured three VTI tunnels between them (one one for business traffic and remaining two for guest services in vrf).
My problem is that I only have 1 public address on both locations and all 3 VTI have to have the same tunnel source and tunnel destination. When I apply tunnel protection ipsec under all of them the tunnels dont work. Is there any solution?
I temporarily configured one location as a DMVPN hub and other as spoke. In this case the VTIs could have the same tunnel source and tunnel destination. To add encryption I configured crypto map under outside interface and ACL has only permit gre any any and it works but I dont like it.
Is there any better way to accomplish it?
thanky ou
5 Replies 5
Use ""shared"" keyword for ipsec profile under vti tunnel.
But Q how you  make traffic pass through specific vti' you need pbr for that.
MHM
peter.matuska1
Level 5
Level 5
I used shared but didnt work.
I use BGP for routing. First vti is in grt, second in vrf A and the third in vrf B
Can I see the config of three vti
MHM
peter.matuska1
Level 5
Level 5
I have just noticed in show crypto ipsec sa that there are mentioned all 3 VTIs. The one thing that I dont like in show crypto ikev2 sa is that under ivrf it says the name of vrf A. I will have to configure the ACL on outside to block
Sorry but your config is wrong below the correct config
MHM
R1#show running-config
Building configuration...
Current configuration : 2650 bytes
! Last configuration change at 13:56:22 UTC Thu Oct 3 2024
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
ip vrf blue
rd 11:11
ip vrf red
rd 1:1
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key mhm address 0.0.0.0
crypto ipsec transform-set trans esp-des esp-md5-hmac
mode tunnel
crypto ipsec profile prof
set transform-set trans
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface Loopback11
ip vrf forwarding red
ip address 11.11.11.11 255.255.255.255
interface Loopback111
ip vrf forwarding blue
ip address 111.111.111.111 255.255.255.255
interface Tunnel0
ip address 5.0.0.1 255.255.255.0
tunnel source FastEthernet0/0
tunnel destination 100.0.0.2
tunnel key 5
tunnel protection ipsec profile prof shared
interface Tunnel1
ip address 15.0.0.1 255.255.255.0
tunnel key 15
interface Tunnel2
ip address 25.0.0.1 255.255.255.0
interface Tunnel25
no ip address
tunnel key 25
interface FastEthernet0/0
ip address 100.0.0.1 255.255.255.0
duplex full
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet3/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet3/1
no ip address
shutdown
speed auto
duplex auto
router ospf 15 vrf red
network 11.11.11.11 0.0.0.0 area 0
network 15.0.0.0 0.0.0.255 area 0
router ospf 25 vrf blue
network 25.0.0.0 0.0.0.255 area 0
network 111.111.111.111 0.0.0.0 area 0
router ospf 5
network 1.1.1.1 0.0.0.0 area 0
network 5.0.0.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
R1(config)#int
R1(config)#interface tu
R1(config)#interface tunnel 2
R1(config-if)#tu
R1(config-if)#tunnel k
R1(config-if)#tunnel key 25
R1(config-if)#exit
R1(config)#
R1(config)#exit
R1#
R1#
R1#
R1#
*Oct 3 13:57:04.127: %SYS-5-CONFIG_I: Configured from console by console
R1#
*Oct 3 13:57:09.143: %OSPF-5-ADJCHG: Process 25, Nbr 25.0.0.2 on Tunnel2 from LOADING to FULL, Loading Done
R1#wr
Warning: Attempting to overwrite an NVRAM configuration previously written
by a different version of the system image.
Overwrite the previous NVRAM configuration?[confirm]
[OK]
R1#
R1#show run
Current configuration : 2665 bytes
! Last configuration change at 13:57:04 UTC Thu Oct 3 2024
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip vrf blue
rd 11:11
ip vrf red
rd 1:1
no ip domain lookup
no ipv6 cef
hash md5
mode tunnel
interface Loopback1
interface Tunnel0
tunnel key 5
interface Tunnel1
tunnel key 15
interface Tunnel2
tunnel key 25
interface Tunnel25
no ip address
tunnel key 25
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router ospf 5
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2#show run
R2#show running-config
Current configuration : 2270 bytes
! Last configuration change at 13:54:13 UTC Thu Oct 3 2024
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip vrf blue
rd 22:22
ip vrf red
rd 2:2
no ip domain lookup
no ipv6 cef
hash md5
mode tunnel
interface Tunnel0
ip address 5.0.0.2 255.255.255.0
tunnel destination 100.0.0.1
tunnel key 5
interface Tunnel1
ip address 15.0.0.2 255.255.255.0
tunnel key 15
interface Tunnel2
ip address 25.0.0.2 255.255.255.0
tunnel key 25
ip address 100.0.0.2 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router ospf 5
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
